All our Different Weld Washers!
Old Jun 21, 2013 | 11:07 AM
Gravel Maker's Avatar
FormerVendor
When we first came out with our Weld Washers 8 years ago they had been made by 20 other companies for years. They were great as a preventative measure when first building a vehicle because they are 7/32" thick but were not as good for repair's. The reinforce a good hole with more than 3/16" of additional steel and come in 1/2", 9/16", 5/8", & 3/4" to cover the bases for you.
Then 3 years ago we added the Fixit Weld Washers. They were primarily for repairing a hole that was already bad from use. They create a clean new bolt hole in 1/2", 9/16", 5/8", or 3/4" and all are 3/8" thick so you don't have to worry about what you fix!
Now just 2 weeks ago we came up with something else along these lines that in some ways is even cooler! Our Threaded Weld Washers. These are used to add something to your chassis in as easy a way you can that is strong enough to stand up to years of use and abuse. They are available for a 5/16", 3/8", & 1/2" thread bolts and require a 3/4" hole to be drilled for mounting so they can be added for anything down to a 1 1/4" Tube and of course any plate or sheet stock.
I seriously see these as something that should be on pretty much any fabricators shelf because there are so many possible uses for them. I am not joking here, these simply make too much sense...
These are all found in our Reinforcements section where we have a whole bunch of things like these
Reinforcement Plates - RuffStuff Specialties
Old Jun 21, 2013 | 11:16 AM
Swimmerboy2112's Avatar
I can't think of a use for these but I'm sure i can come up with something, these are awesome! I'm diggin the threaded ones!
Old Jun 21, 2013 | 01:41 PM
FormerVendor
Trust me, we thought the same thing, until we started working on my FJ45. These came in great handy!
Old Jul 24, 2013 | 05:46 AM
FormerVendor
Quality is key!
Old Sep 19, 2013 | 10:33 AM
FormerVendor
Bringing this back to the tops!
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
tazman1972
11
Sep 28, 2015 10:32 PM
runnermedic
13
Sep 21, 2015 05:20 PM
VT2LAB
Sep 10, 2015 09:36 AM
