Marlin Crawler Weekly Specials!
Old Feb 25, 2011 | 02:40 PM
BigMike's Avatar
Every week we run a special between each Friday at 4pm PST
This week we are offering our new Gasket and Seal rebuilt kit for 25% off!
You cannot find a more complete gasket set anywhere. This is a great rebuild kit using all OEM Toyota gaskets and seals. We've also included our Heavy Duty transmission EcoSeal output at no additional cost!
http://www.marlincrawler.com/transfe...al-rebuild-kit
Old Mar 4, 2011 | 02:16 PM
BigMike's Avatar
This week's Special Product is our 30-spline Chromoly Front Output Shaft Kit! Featuring up to 23% larger diameter than stock, this is hands-down the strongest front output shaft on the market.
Get your paws on this kit at 25% off retail now through March 11th!
Link to product page: http://www.marlincrawler.com/transfe...t-output-shaft
Product comparison and detailed instructions available online.
Old Mar 15, 2011 | 10:25 AM
BigMike's Avatar
This week's special product is our FJ80 Knuckle Service Kit!
This high quality kit is complete with new wipers, felts, gaskets, lock washers, inner axle & bearing seals, hub gaskets, High Quality Japanese NSK knuckle bearings and two of our FJ80 Heavy Duty EcoSeal inner axle seals!
Take advantage of this limited time offer and save 25%!
Product link: http://www.marlincrawler.com/axle/fr...rvice-kit-fj80
Old Mar 18, 2011 | 03:07 PM
BigMike's Avatar
This week's special product is our Heavy Duty Transmission output EcoSeal! Your choice of either 21- or 23-spline, we've got em all on sale for the next week at 15% off! This is the best transmission output seal on the planet with the same great features that made our Heavy Duty Inner Axle seals world famous! Keep your clutch dry and your transmission safe today!
Product link: http://www.marlincrawler.com/transmi...on-output-seal
Old Mar 26, 2011 | 10:32 AM
BigMike's Avatar
This week's special product is our Top Shift Conversion Kit! Now is your chance to save 15% and convert your forward shift case using our high quality billet and heat treated parts! Comes with double-rolled HD pins with forks designed to fit our 4.70:1 gears without any modifications!
Product link: http://www.marlincrawler.com/transfe...conversion-kit
Old Apr 4, 2011 | 11:07 AM
BigMike's Avatar
We now have both standard and rotated Xtreme Duty MC07 Adapters ready to go! This is a very exciting time for us because we've been waiting for the standard XD versions and now they are here! So to officially kick the Xtreme Duty Dual Case Adapter off, we are offering either kit at 15% off for 1-week!! This is a GREAT deal on the strongest Toyota dual case adapter in the world!!
Exclusive Xtreme Duty features not found anywhere else:
  • Double Rolled Maximum Capacity Main Shaft Bearing minimizes axial flex to extend coupler and input life
  • Chromoly Coupler for maximum spline strength, durability, and longevity
  • Oversized Heavy Duty Cage Bearing combats extreme temperature and pressure
  • HD Cage Bearing is 52% stronger and features a machined cage instead of flimsy stamped steel
  • Radiused Coupler for increased pocket bearing oiling
  • Heavy Duty Plate Webbing for increased rigidity
  • Thrust Washer Lock System to prevent wear, debris in oil, and metal-on-metal friction/heat
  • Huge Shelf Oil Passages capture and transfer way more oil
  • Multi-bolt Retention System designed for optimum load spreading
  • Japanese Industrial Standard (JIS) Heavy Duty Metric Fasteners
  • CAD Optimized Light Weight Adapter Cutouts to increase oil capacity and save weight
  • Unique Margasket to simplify installation
  • Complimentary EcoSeal Transmission Output Seal, the most versatile and effective output seal
Product Link: http://www.marlincrawler.com/transfe...-drive-mc07-xd
BigMike
Old Apr 8, 2011 | 04:30 PM
BigMike's Avatar
This week's sale item is our USA-made High Steer Kit. Complete with amazingly strong Billet USA Steel High Steel Arms, USA DOM drag-link and tie-rod bars, special pitman arm and massive FJ80 tie rod ends, this kit doesn't disappoint. For 1 week only we are offering this kit for just $349! That's nearly 20% off!
Additionally, if you purchase our Competition Series 25mm Pin Upgrade Kit with the High Steer Kit, we'll knock off $50 bringing the combined savings to over $125!
Check it out! It's a fine time to upgrade your steering system!!
Hilux Kit: http://www.marlincrawler.com/steerin...teer-kit-hilux
FJ40 Kit: http://www.marlincrawler.com/steerin...steer-kit-fj40
FJ60 Kit: http://www.marlincrawler.com/steerin...steer-kit-fj60
25mm Upgrade Kit: http://www.marlincrawler.com/axle/fr...in-upgrade-kit
Old Apr 15, 2011 | 04:33 PM
BigMike's Avatar
Ok guys,
We've got something a little different this week. Back by an overwhelming demand, we are putting our MC07-XD Kits up for another weekly sale! This repeat offer of 15% off is ONLY good until the 22nd, after which we will be changing the regular retail price.
This is your last chance to act now! We won't be putting the MC07-XD on sale for a while!!
Product link: http://www.marlincrawler.com/transfe...-drive-mc07-xd
Take advantage of this last sale offer and get Crawling by summer!!
BigMike
Old May 7, 2011 | 06:53 PM
BigMike's Avatar
Last week we put up a great COMBO deal on our Huge 30-Spline Chromoly Output shafts.
http://www.marlincrawler.com/transfe...r-output-shaft
When you purchase our rear output kit (shown above) you can get our front output kit (shown below) at HALF PRICE!!
The deal was a HUGE success! We moved a bunch of these kits and are glad to help the Toyota community make their trucks as reliable as possible!!
Regards,
BigMike
Marlin Crawler, Inc.
Old May 7, 2011 | 06:54 PM
BigMike's Avatar
We have now sold more than 30,000 inner axle EcoSeals, so we thought we'd celebrate by writing an updated tech article and by putting the EcoSeals up as the weekly special by offering you a buy 1 get 1 free deal now through next Friday!
Help us celebrate this great milestone for our EcoSeal and prevent oil leaks on your truck at the same time!
For Hilux EcoSeal: http://www.marlincrawler.com/axle/fr...xle-seal-hilux
For FJ40-FJ62 Land Cruisers EcoSeal: http://www.marlincrawler.com/axle/fr...seal-fj40-fj62
For FJ80 Land Cruisers EcoSeal: http://www.marlincrawler.com/axle/fr...axle-seal-fj80
This buy 1 get 1 free is a limited time offer and expires next Friday. The offer is available one per customer. If you order 1 seal, you will receive 2 for the price of 1. If you order 2 seals, you will receive 3 for the price of 2, and so on. Thank you for joining in on the celebration!! Offer expires Friday May 13 at 4pm PST.
Regards,
BigMike
Old May 13, 2011 | 03:19 PM
BigMike's Avatar
This week we are putting our Knuckle Stud Kit up for grabs at a really great price! This great deal will save you $12 on a full set for your truck! Genuine Toyota parts, made in Japan. Great time to replace worn parts or stock up on spares
Product Link: http://www.marlincrawler.com/axle/fr...uckle-stud-kit
Old May 20, 2011 | 03:31 PM
Alejo2112's Avatar
Hi i need to buy both rear axel shaft for a FJZ80, 1996. Semi-float.
I can´´t find CR-MO axel, only OEM.
The Toyota original P/N : 42311.
my email: alejandro@equipatu4x4.cl
Old May 27, 2011 | 03:06 PM
BigMike's Avatar
Last week we offered our high quality Japanese spindle nut kit at an incredible 40% off!! It was s GREAT sale and we shipped out a ton of these kits!! Thank you to everyone for your orders!
This week we are offering our extremely strong "4-30" four pattern 30-spline flanges at 25% off! These flanges fit our heavy duty chromoly 30-spline gear drive output shafts, as well as 1988-1995 V6 Hilux & T100 and 1995+ Tacoma/Tundra/FJ Cruiser/4Runner chain drive transfer cases.
This flange is more than twice as thick as the stock flange, so........ yeah, its seriously strong For a limited time, save nearly $10 on this flange no through next Friday!
Product link: http://www.marlincrawler.com/transfe...-spline-flange
Old Jun 11, 2011 | 08:12 AM
BigMike's Avatar
Last week we put our very popular Axle Breather kit up for grabs at 15% off retail!
Product link: http://www.marlincrawler.com/axle/re...e-breather-kit
This week's special is pretty cool! We have thrown together a new Clutch Combo Upgrade Kit that will convert your 1979-1992 8-7/8" clutch setup to the much larger Turbo 9-5/16" setup!!
This Clutch Upgrade Combo Kit includes everything needed to convert over:
  • Larger 1,200-lb Heavy Duty Turbo Rock Crawling Clutch Kit
  • New 9-5/16" Turbo Flywheel
  • Heavy Duty Pressure Plate Bolt Kit
All parts are simple R&R with no modifications required. L43 4-speed setups will require a 1981-95 22R(-E) starter for compatibility.
Save $70 with this sweet combo deal! Offer expires next Friday, 6/17!
Product link: http://www.marlincrawler.com/clutch/...rade-combo-kit
Regards,
BigMike
Old Jun 11, 2011 | 09:28 AM
Elton's Avatar
good stuff to bad its like 15 dollars to ship little stuff cause they dont offer usps
Old Jun 11, 2011 | 12:33 PM
spc mike's Avatar
Little stuff?!? That flywheel alone weighs like 25 lbs !
Old Jun 17, 2011 | 03:14 PM
BigMike's Avatar
Thank you to everyone who upgraded their clutch with our combo kit! It was a HUGE success!!
This week's special product is our custom length Heavy Duty Long Spline Front Drive Shaft! These drive lines pack a punch at 25% larger diameter splines, 160% thicker walls, and up to 65% increased droop angle! Now available for 1 week at 10% off -- a savings of up to $42!
Click here for more info: http://www.marlincrawler.com/axle/dr...ront-driveline
Old Jun 24, 2011 | 03:04 PM
BigMike's Avatar
This week's special is a fantastic High Steer and Knuckle Stud Kit combo!
Now through July 1st, when you purchase 1 pair of our made in USA billet steel High Steer arms, we'll include a complete set of knuckle studs, nuts, cones, and washers! This is a great time to upgrade your high steer arms and save nearly $60 on mounting hardware!
Product link: http://www.marlincrawler.com/steerin...igh-steer-arms
We love bringing you guys these sweet deals every week!!
Regards,
BigMike
Old Jul 6, 2011 | 12:02 PM
BigMike's Avatar
Ok guys!
This week's special is one FREE Gasket and Seal Rebuild Transfer Case Kit when you order one of the following products:
30-Spline Chromoly Front Output Kit
30-Spline Chromoly Rear Output Kit
Dual Case Kit (MC07-XD)
Dual Case Kit (MC08)
This is a $49 savings and will get ya the most complete gear drive transfer case gasket and seal rebuild kit on the market, even includes two EcoSeals!
Click here for more information: http://www.marlincrawler.com/transfe...al-rebuild-kit
Offer expires Friday, July 8 at 4pm PST.
BigMike
Old Jul 6, 2011 | 12:42 PM
Elton's Avatar
lol no i mean like seals and stuff nothing over 5lbs
