Maintenance May is back!
Old May 9, 2017 | 04:05 PM
BigMike's Avatar
Maintenance May is back after its two year hiatus offering almost $800 in savings across the following 39 products!
- 12mm Upper Knuckle Stud Kit -- 3-speed Rebuild Kit -- 4-speed Rebuild Kit -- 8/80-1/90 Split Case Rebuild Kit -
- 8mm Hub Stud Kit -- Chromoly 30-Spline Axle Kit -- Chromoly UM07 Marfield, 27-spline -- FJ80 Front Axle Service Kit -
- FJ80 Knuckle Gasket & Seal Kit -- FJ80 Knuckle Service Kit -- Front Axle Service Kit -- Front Wheel Bearing Kit -
- Full Rebuild Kit -- Gasket and Seal Rebuild Kit -- HD FJ80 Inner Axle Seal -- HD Inner Axle Seal -
- HD Inner Axle Seal -- HD Transfer Case Rear Output Seal -- Heavy Duty Pinion Seal -- Heavy Duty Rear Axle EcoSeal -
- Heavy Duty Transmission Output Seal -- High Steer Kit for FJ40 -- High Steer Kit for FJ60 -- High Steer Kit for Hilux -
- Knuckle Gasket & Seal Kit -- Knuckle Gasket & Seal Kit -- Knuckle Service Kit -- Long Frame Bushing -
- Push N Turn Shifter Base Kit -- Short Throw Shifter Kit, G52 -- Short Throw Shifter Kit, G54 -- Short Throw Shifter Kit, G58 -
- Short Throw Shifter Kit, R150F for 3.0-liter -- Short Throw Shifter Kit, R150F for 3.4-liter -- Short Throw Shifter Kit, R151F -- Short Throw Shifter Kit, W56-A -
Now is a great time to Get your truck ready for the summer wheel'n season with Marlin Crawler!
Maintenance May ends May 31st
http://www.MarlinCrawler.com
Old May 9, 2017 | 04:33 PM
flg8r22's Avatar
No love for the L43 ? I need seat/seal/shifter bushings. I will be ordering some of those goodies tho!
Old May 11, 2017 | 11:20 AM
BigMike's Avatar
PM Sent!
