Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
What are you doing for rear bump stops?
Old Feb 24, 2024 | 03:29 AM
prcnctoyo's Avatar
What are folks using for rear bump stops? I pulled mine off a few years ago. They had rusted to the point of almost falling off. I pulled a set from a junk yard. They are in ok shape but still have rust. I cleaned and painted but rust is coming back. Before I can get them on I have to extract the bolts from the frame where the heads sheared off.
So I've been thinking do I use the used ones with rust or do something different. I haven't found any aftermarket ones that match the bolt holes of the 2WD OEMs. Has anyone used the 4WD bump stops with U bolts over the frame? With this I'd have to make a plate to go on the top to slide the u bolts ends in and bolt down on.
Old Feb 26, 2024 | 08:16 AM
Paul D.'s Avatar
Not sure what rig you are driving but for my 99 4 runner there are these available:
https://parts.lakelandtoyota.com/p/T...830660121.html
Old Feb 26, 2024 | 08:49 AM
prcnctoyo's Avatar
Thanks for the suggestion. Those won't work on my truck. My rig info is in my signature 22R 1987 2WD Truck long bed. The ones I need are discontinued.
Old Feb 26, 2024 | 11:51 AM
Paul D.'s Avatar
Oh sorry, I see that now. Yeah mid 80's is tough. All I can find on that is the following:
https://www.yotashop.com/bump-stop-t...8-48306-35170/
might be able to modify it to work.
Old Feb 26, 2024 | 02:57 PM
prcnctoyo's Avatar
Thanks. That's the style I'm thinking of using with u bolts and a fabricated plate to go over the frame. The 2WD bump stops bolt in to the frame above the axle.
Old Feb 27, 2024 | 06:56 AM
rattlewagon's Avatar
This is how I do it. Piece of tube with a generic bumpstop on it. Cut to whatever length you need.
Old Nov 18, 2024 | 09:37 AM
yotmi's Avatar
For rear bump stops, retain the stock ones for standard use, but consider extended or adjustable options if you have a lift or larger tires to prevent bottoming out. Polyurethane bump stops are durable and offer better performance under load. Hydraulic bump stops are ideal for off-road applications, absorbing impacts smoothly. Ensure proper sizing and adjustability based on your suspension setup. Always match bump stops to your vehicle’s needs for optimal performance.
MasterOfNone
Nov 4, 2020 01:22 AM
wyoming9
Nov 9, 2015 11:46 PM
surfh2o
Feb 16, 2009 08:41 AM
onesojourner
7
Aug 27, 2007 04:55 PM
dfoxengr
Jun 6, 2007 10:52 AM
