Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
Help with exhaust manifold gasket problem
Old May 16, 2011 | 08:38 PM
WKahle11's Avatar
So yesterday we replaced the clutch in my 94 pickup, and we took the exhaust off to get to the transmission and when trying to fit it back to the flange we stripped the studs out and we had to replace them. That meant we had to take the manifold off. So we got that off and redone and we got all the gaskets replaced except for one.
This one is on a pipe that comes off the manifold, and goes straight back towards the cab and then straight down. Before it goes down its bolted together and there is a gasket in there. Trying to get it all off we broke the gasket and we cant find a new one anywhere we look. Does anyone know where I could find this one?
Old May 17, 2011 | 06:16 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
According to the FSM, that tube is part of the Air Suction system (which I believe is more commonly called the PAIR system, at least here on YT anyways) which blows air into your exhaust. Assuming you mean the tube that has the two tubes coming off it that go to the exhaust manifold and looks kinda like an F on it's side.
Dealership should be able to get the gasket.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
