Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
4x4 spindles on 2wd a arms?
Old Dec 14, 2011 | 02:35 PM
ffryno13's Avatar
Will 4x4 6lug spindles fit on the 2wd? I have 4x rearend that I want to put on my truck but didn't want to play the mis match game on wheels.
Old Dec 17, 2011 | 06:59 AM
deserttoy84's Avatar
would require a custom upright to bolt a 4x solid axle spindle to it. or somehow modify a stock 4x ifs setup.
Old Dec 20, 2011 | 08:18 AM
Land Pirates Off Roa's Avatar
If you are running the stock 2 wd suspension, yes, there is a racing spindle swap... Several actually.... Depends on what year you are running... I can not tell, you did not post that. But it is a lift spindle... Runs the 4x4 brakes and hubs. But you have to have a uniball long travel front A-arm set up.
Or you can go custom... 2 inch snout with racing hubs and brakes.... But again, need that uniball front end.
If not, we can adapt a 85 straight axle spindle and snout / brakes to your 2wd spindle.
Old Dec 21, 2011 | 09:46 PM
ffryno13's Avatar
It's not going to be a Prerunner anytime soon or ever. But I ll use the truck for auto x and drifting I just want it to be strong and have the bigger brakes.
It's a 1990 stock 2wd spindles
Old Dec 22, 2011 | 07:59 AM
With bigger tires or just high speeds, the stock brakes will fade out. Spooky to say the least when it happens...
Even with the stock 2wd spindle, you have have a bigger brake. Depending on what sized rim you are running, you can cram a big rotor in there...
17 inch rims will handle most 14 inch rotors... The bigger the diameter of the rotor, the more torque you have and better modulation (feel) Even a 13 inch rotor will have better feel than a 12 inch... But a 12 x 1.25 will haul you down from speed faster than you can accelerate.
Old Dec 22, 2011 | 08:01 AM
And if you are just looking for bigger brakes, that is much easier to do than upgrading your bearing sizes... If you are not pounding the hell out of your truck of road, the 2wd spindles will be just fine with proper maintenance.
Colington
Mar 8, 2020 09:51 AM
KyleT
Jul 21, 2015 07:54 PM
1994toyota
Jul 17, 2015 03:03 AM
colasurdo
Jul 16, 2015 11:32 AM
hexrain
Jul 12, 2015 01:13 PM
