Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
3y engine new weber carb
Old Aug 27, 2021 | 02:57 AM
Alpha Moth's Avatar
Hey guys I need some help. 1984 hiace, 3y engine, Yh61 series
I have a 32/36 DGEV weber carburetor on a 1984 hiace with a 3y Engine. The old carb was useless. The new carb doesn't have a vacuum port for the PCV valve. In the past I have just stuck the PCV valvle into a bottle and left the breather open. I noticed I started to get some oil leaks about a year later of this method of just venting into the atmosphere, so I swapped my PCV valve for a new one however this hasn't solved the problem. Some oil will come out the breather hole unless I have the dipstick or PCV valve removed. It seems that the PCV is bad even though it is new, but I can suck on it and it will open. Maybe it needs some vacuum. Where can I route a vacuum line to? On the underside of my air filter housing there is a hole, would it be okay to put into that? Or does it need to go under closer to the intake manifold.
Hoping adding a vacuum to draw out the gasses will stop the oil being pushed out elsewhere.
Cheers
Triple
Mar 4, 2017 02:08 PM
dhickman
Mar 10, 2014 11:42 AM
rusty yota
Aug 30, 2010 02:09 PM
Jeffp
Apr 11, 2010 04:33 PM
aadown1214
Mar 7, 2009 08:45 AM
