Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
2wd/suspension to 4wd frame swap
Old Oct 29, 2015 | 04:07 PM
Lifted94XLT's Avatar
ok guys, I have a question. I am picking up an 87 2wd pickup on Saturday that I got a great deal on, but it had frame rot. I have a 4wd IFS parts truck with a good frame. after searching for hours on the net with no luck, I'm asking you guys here. I want to swap in the 4wd FRAME but keep the truck 2WD. Other than the front clip (radiator support) having different body mounts, what are the other differences in the frame? mainly the suspension between the 2wd/4wd ifs. How much fabbing will need to be done to accomplish this?
Cliff Notes::
2wd Truck --> Swap in 4WD Frame --> Stay 2WD --> Is it possible without a buttload of fab work??
Thanks guys for any info you can give.
--Ryan
Old Oct 29, 2015 | 11:47 PM
Robert m's Avatar
If I'm following what you are asking correctly, it wont be worth the effort. The frames and suspensions between a 2wd and 4x4 truck are totally different. Every suspension mounting point, suspension component, and even the frame dimensions are different. To try and make the 4x4 frame accept the 2wd suspension parts would be a royal P.I.T.A.
To make a 4x4 into a 2wd, you would be much better off finding a 2wd 2nd gen 4runner thats being parted and using the hubs and spindles and then remove the CVs and front diff. No fab work needed.
Old Nov 15, 2015 | 03:50 PM
Thanks for the help, I am going a different route. I cut the rear half of my 4wd frame off and will be grafting it onto the rear of my 2wd truck. little more work but nothing I can't handle.
--Ryan
May-39
Sep 6, 2015 01:05 PM
A2theK
Sep 4, 2015 03:16 PM
Lcb98toy
11
Aug 26, 2015 05:28 PM
DirtRoad93
Aug 23, 2015 05:50 AM
juandulce4runner
Aug 21, 2015 07:30 PM
