Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
2WD Axle Shaft Replacement
Old Aug 24, 2011 | 10:08 AM
Motocompo's Avatar
Gotta an issue you might be able to help me out with...
Last year my 86' 2WD truck spun into a curb during a rain storm and bent the drivers side axle shaft. Some new wheels and tires later and the truck is still kicking today, although the drivers side rear wheel wobbles (+/-3 degrees off center) from the bent axle shaft. Upon closer inspection, I've found that I have the 1 ton axle (30 spline) which is proving difficult to find a replacement for. I either find highly overpriced complete 1 ton 2WD axle assemblies or 1 ton axle shafts for 4WD (6 lug pattern versus the 5 lug on the 2WD). I would ideally like to keep the 1 ton axle and my current bolt pattern.
Any ideas on how I could fix this? Money isn't a huge issue as much as if I'm gonna be forking out some cash, I'd rather get a 'better than stock' new parts versus decrepit 25 year old parts.
EDIT: After a little bit of searching, I've come across a part number for Toyota Parts Zone that should fit the bill, however I would still like to leave this open to aftermarket options if they exist.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
andrewtexas123
Jul 14, 2015 04:29 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
