Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
Cougar House Garage 3rd Gen 4Runner 4Wheel Underground Diamond Axle 3link buil
Old Mar 2, 2017 | 09:17 PM
  #41
CougarHouseGarage's Avatar
Made the reviver to the rear axle brake lines today
Installed the radiator to
Old Mar 3, 2017 | 10:09 PM
  #42
Made the next 1/0 cable to go from the fire wall bulkhead fitting to the SMD power distribution block
Had to mount the power block a little sideways to mount flat on the inner fender
We used self tapers tell we get hardware
Then back to the battery
Old Mar 4, 2017 | 06:52 PM
  #43
Terrys87's Avatar
I wish I had a 1/10th of your fab skills. You got some serious work going on. Great job!!!
Old Mar 4, 2017 | 07:02 PM
  #44
Made the brake hard lines
The little zip tie is temporary
Old Mar 6, 2017 | 05:45 PM
  #45
Installed a electrical bulkhead for the ground to go the frame and made the top half ground cable
Maintaining
Old Mar 9, 2017 | 10:16 PM
  #46
Hydro lines ran, zip tied along the panhard bar for now tell aluminum clamps come to mount it along there.
Steering shaft from a 81' toyota pickup
We cut up the 3rd gen factory joint up and welded the splined part on the Borgeson joint
Old Mar 9, 2017 | 10:18 PM
  #47
Old Mar 10, 2017 | 06:44 PM
  #48
This the only spot I could have the Trail Gear power steering rezivor live and keep the return line in the rezivor above the line from the High presser pump
Old Mar 10, 2017 | 08:07 PM
  #49
Reinstalled the Diamond Axle Rear Hubs
Old Mar 10, 2017 | 10:28 PM
  #50
Moved the Magnaflo muffler back 8'' out of the way of the 4WU lower link brackets
Pulled it out to fully weld
Installed
Old Mar 12, 2017 | 09:49 PM
  #51
Finished up the T_case mount
Old Mar 13, 2017 | 07:01 PM
  #52
81' Toyota truck steering shaft
Then two Borgeson u-joint's. Im going to finish it with two toyota u-joints so this will work tell I can sources some.
Old Mar 15, 2017 | 05:38 PM
  #53
Cougar House Hanging out at the 2017 Moonshiners swap meet an truck show, the Dune 4Runner got a really good reception
Old Mar 15, 2017 | 09:02 PM
  #54
Old Mar 16, 2017 | 10:15 PM
  #55
Old Mar 17, 2017 | 08:33 PM
  #56
Fiberwerx 2002 Tacoma Front end converstion
Old Mar 18, 2017 | 01:18 PM
  #57
24'' frame to ground ride hight
Old Mar 19, 2017 | 10:31 PM
  #58
Dam it just looks good
Old Mar 20, 2017 | 01:25 PM
  #59
Back home from the show
Old Mar 20, 2017 | 01:48 PM
  #60
