Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
Denver Colorado Mechanics
Old Nov 8, 2013 | 02:58 PM
Hunt Gath's Avatar
Originally Posted by snobdds
The proper way to change a timing chain is to remove the head, repalce timing components, replace the head gasket and seal the top of the timing cover to the head. Then there are no leaks and you don't have to worry about your head gasket until your chain needs replaced again. Also, this way prevents one from having to go back in and replacing the head gasket at a later date. Then you might as well do your timing chain again since your already in there. See the cycle here. To not pull the head, the mechanic has to squeeze the timing cover back in and it never gets a good seal. A good mechanic will only quote the job this way, FYI.
I guess watch for leaks...
Will do, appreciate the info.
RobotMoose
Feb 22, 2020 07:44 AM
calderp
Nov 16, 2015 02:49 AM
YotaPagota
Sep 20, 2015 06:24 PM
metalhed
Sep 8, 2015 10:54 AM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
