93-98 T100s (Build-Up Section) Post your build-ups here
Transmission fluid change
Old Jul 17, 2020 | 04:19 AM
Ram1's Avatar
I changed the engine in my Toyota T100 automatic 4x4. I added new dexron3 fluid and started the engine to circulate the fluid and get a more accurate reading on the dipstick. After warming it up and finishing the fluid fill, I decided to give the truck a test drive only it would not move. I checked the solinoids, the inner wiring harness inside the transmission pan and I can't seem to find anything wrong with it. Anyone else have this problem? Did you find a cure? If you did, would you mind sharing it with the rest of us? Thank you very much in advance. Have a great day and be safe out there in the jungle.
bmwpower
Apr 16, 2007 07:04 AM
2wheelBLACKOUT
20
Dec 12, 2005 06:37 AM
mielkep
Oct 9, 2004 08:04 PM
valkrien
Sep 26, 2004 08:19 PM
lilwily
15
Mar 17, 2003 05:09 AM
