no brakes ?
Old Oct 25, 2013 | 05:11 AM
hoghead420's Avatar
no brakes ?
The last few days my brake light on the dash has been flashing on then back off . Last night I was in the 4runner sitting in the driveway and the light came on , I pumped the pedal a few times seeing if it would turn off . All the sudden the pedal lost pressure and hit the floor . Today I popped the hood and the breakers fluid Res is empty , seems to be a very small puddle under the motor area . I'm no brake expert , wondered if anyone had a similar experience and what the problem ended up being .
Should I add more brake fluid to use to find the leak ? How does a shop find the leak ? Air pressure? Other than changing pads I suck at brakes . The truck has 185,000 miles just in case it helps . Any comments or ideas would be great , thanks ytech
Old Oct 25, 2013 | 05:14 AM
Leicesteryota's Avatar
Bad booster
Old Oct 25, 2013 | 05:16 AM
hoghead420's Avatar
Is there a way to test it to be sure ?
Old Oct 25, 2013 | 05:18 AM
Pump em up and listen to see if there is a hissing noise as the pedal goes to the floor . Therefore it's leaking pressure . Or if that's not the case you could have a broke line or a kinked line allowing air into the break system
Old Oct 25, 2013 | 05:20 AM
hoghead420's Avatar
OK , will give it a shot , thanks ,
Old Oct 25, 2013 | 05:22 AM
No problem be sure to post back and tell if that was it
Old Oct 27, 2013 | 02:46 AM
hoghead420's Avatar
It turned out to be a busted rear brake line passenger side , the ground was all wet from rain and I couldn't see a puddle where it leaked . I replaced with a 30 inch line from parts store , did the one man brake bleeding and it seems about like it was before it went out , I will have help today , so I'm going to bleed em again and hopefully it gets a little stiffer . Thanks for the heads up on the booster, when it goes I'll know the symptoms.
Old Oct 27, 2013 | 05:05 AM
No problem glad to hear you got it fixed!
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
