You decide ...how much lift ???
Ok all,
You get to decide how much I lift my 99SR5 4WD.
I want to do a mild lift on my truck to allow me to run some slightly bigger tires for mild off roading. I use the truck (my only vehicle) on road so it must not badly compromise on road manners.
I plan on retaining the addco bars with a NUKE disco up front.
I want to run 32's (do not want all the issues associated with 33's) as they can go on my stock rims.
I have some Bilstiens on the way so was thinking about 1.5" cornfeds all round with stock springs.
Over to you.....
Over to you.....
1" cornfed front spacer to keep wear down on the boots up front with your daily driver.
1" longer Nuke Discos.
1.5" cornfed rear spacer. I like the rear a tad higher. A set of Schaefers bumpstop lowering bracket and super soft bump stops, since you will loose the bumpstop inside the coil.
32" Goodyear MTR's. I am not sure how good these are for on-road performance. Any comments? If they wear too fast or do not handle decent on-road I would say get a nice set of AT's perhaps BFG TA KO's..
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Backcountry411
Jul 24, 2015 08:06 AM
