Would you rather have a sunroof or NO sunroof?
Old Oct 12, 2008 | 09:34 AM
kingbrian's Avatar
i hate mine in my 85... in the summer i have no where to hide and in so cal the sun will burn you in no time... way to much glass not enough protection.. oh and its aftermarket and has no cover, if i had the choice id definitely go with no sunroof
Old Oct 12, 2008 | 09:35 AM
86Crawler's Avatar
Mine is not electric either
Old Oct 12, 2008 | 11:06 AM
JasonWin's Avatar
I love my factory Sunroof in my 85. I just take the glass right out sometimes. All I need now is to make some half doors to really feel open
Old Oct 12, 2008 | 01:38 PM
duel's Avatar
Aviator: Sunroofs do not necessarily weaken the structure of the roof. Aftermarket sunroofs, yes they make the roof very weak. But factory sunroofs in cars with pop-up non electric roofs actually make them stronger! They add a ton of bracing and instead of just being a flat panel, it acts similar to an "I" beam, to allow less flex.[/QUOTE]
x2!!!...I have owned both and I will say that my single cab w/out sunroof was so WEAK compared to the stiffness in my xcab w/factory sunroof. The roof is much stronger on a factory sunroof toy truck versus non./
Old Oct 12, 2008 | 02:52 PM
  #25
02SE's Avatar
The Moonroof on my '97 'Runner was an absolutely essential option to me, when I bought it just over 11 years ago. Never any problems with it.
Old Oct 12, 2008 | 03:25 PM
  #26
habanero's Avatar
Wasn't looking for one but it came with the truck so....
No leaks. Don't know about strength, but I wheel (mild to lightly moderate) with 2-3 5 gallon solar showers about a foot or two behind it, tied to the front of the rack, without a sound. If I tie them up near the back of the truck it sounds like oilcan city up there.
Now I've done did jinxed myself with that whole leak thing, didn't I?
Old Oct 12, 2008 | 04:54 PM
  #27
P-Lo's Avatar
I think it would suck out loud if I didn't have a sunroof. I enjoy the airflow and the sun, as well as the stars on a mild night. As for water leakage...YUP, I had that too. I solved it by thoroughly cleaning all of the rubber around my glass and the metal frame that the rubber comes in contact with. Last winter I had some pretty bad leakage, and after my cleaning I've been dry as a bone. It's like a h20 proof camera. A single grain of sand in the seal can f-up the whole thing.
That's my 2 cents.
Old Oct 12, 2008 | 05:03 PM
  #28
GenXr's Avatar
No sun roof. Extra hassle if it leaks or breaks and like others said, no where to hide from the sun in a pickup. I'm perfectly happy with my slider rear window.
Old Oct 12, 2008 | 05:39 PM
  #29
RutRipper's Avatar
Originally Posted by crolison
no sunroof, cool idea, but i would rather not have another electric gizmo break.
agreed, i know this may sound dumb but i hate all the electric stuff...even the electric window..I like having stuff that won't go out and if it does it's easy to work on.
Old Oct 12, 2008 | 05:48 PM
  #30
JasonWin's Avatar
I agree with that, but my sunroof doesn't have any electric gizmos!
Old Oct 12, 2008 | 06:03 PM
  #31
DeathCougar's Avatar
Not true. Toyota made a sunroof sunshade the kept you perfectly shaded from the sun!
Old Oct 12, 2008 | 08:03 PM
  #32
Rock Slide's Avatar
I wasn't looking to purchase a 4Runner with a sunroof when I bought mine, but it has been a nice bonus. I open my s.r. any chance weather permits. Never had a leak either.
Old Oct 13, 2008 | 05:59 AM
  #33
X-AWDriver's Avatar
Remember that this thread is for 3rd gen sunroofs since it seems people are confusing the issue with older non-power sunroofs and with no sunshades. The modern ones are obviously improved over the older Toyota versions.
I love mine and wouldn't want a Runner w/o one.
Old Oct 13, 2008 | 10:06 AM
  #34
unitofstuff's Avatar
Originally Posted by dairyjato
i love mine open the sunroof and roll the back glass down and you can pull a good breeze w/o all the noise like your side windows make. the only time mine let water in it was open. 10years old and no leaks
I fully second this. Sunroof open and back window down at 60mph will barely ruffle your hair.
Old Oct 13, 2008 | 10:08 AM
  #35
surf4runner's Avatar
X2
its lets in too much dust if i leave it open on a trail
Old Oct 13, 2008 | 10:55 AM
  #36
904_runner's Avatar
Mine is electic. Notice how toyota put that little screw function near the maplights that allow you to still close it even if the motor fails????
I use mine, some times ill open it, not too often.
But for the longest time i would drive around with the cover back so i could still see outside. Lately ive just had the cover closed so it acts of no sunroof.
I like mine!!!!!
Old Oct 13, 2008 | 10:56 AM
  #37
904_runner's Avatar
Originally Posted by surf4runner
X2
Z
Yea, and if you forget its open and splash through a puddle, then it lets in water!
ask me how i know
Old Oct 13, 2008 | 11:06 AM
  #38
Maj's Avatar
Maj
Since I use my sunroof pretty much year-round it gets a workout. No problems with malfunctions or leaks. The 2nd Generation 4Runners had a manual crank so you could close it in the event of motor failure. The 3rd Generations don't have that - probably because Toyota figured the reliability didn't warrant the need for it.
Old Oct 13, 2008 | 12:05 PM
  #39
I didn't search for a truck with it when I bought mine but it happened to have it. I hardly ever use it as the sun is plenty strong here, it is nice when driving a looking up at nice views but I would rather have more headroom.
Old Oct 13, 2008 | 09:14 PM
  #40
nieuwendyk-25's Avatar
They all leak a little, it just drains out the drain tubes. Those must be kept clear or you will have a problem.
Whoever said the aftermarket ones don't have the drains was wrong. The good ones do! I have an aftermarket one on my Altima and it is awesome (it is a Webasto). It will even close on its own when you turn the car off. It doesn't have the horrible Toyota pause either. The only negative to it, is there is no solid headliner. The headliner is just stretched from it to the sides...no hard cardboard support. That is the only negative....and it does have a cover. That one is 12 years old and has never leaked.
I love the one on my 4Runner except for the pause when it closes. The Sequoia one does not do that. I mostly keep mine closed and just use the glass. I have them on all my cars except the Jeep (I just take the top off of it). I will always have one.
