wiring diagrams needed
Old Mar 26, 2014 | 02:47 AM
TheDurk's Avatar
Originally Posted by 22REFORME
Aside from this one plug that comes from the truck the other plugs come from the 97 harness, ie are already wired properly. So it matters if these pins in this plug are input or output. Basically if these wires are telling the ecm something then it should be ok, but if the ecm is telling the truck something then I need to get FC from the other plug.
That make sense?
Yep, and as I point out in my edit, FC is the ECU telling the fuel pump to run. So yeah, you need it.
Old Mar 26, 2014 | 02:52 AM
TheDurk's Avatar
Once thise one plug is sorted at the ecm, I need to find the pinouts for the engine harness to truck harness connections. Any idea what that is called? These are the plugs I posted pictures of.... the grey plug with the white plug
That is also in the EWD. It's called "Connector Joining Wire Harness and Wire Harness". They are separated by location on the truck. Here is that section from the 2002 EWD, so you have an idea what to look for...
http://tacoma.site40.net/4Runner_96-...c/connecto.pdf
Then we have to go back to the wire diagrams and track down every wire that feeds into that plug and do the same on the other side, and then figure how to marry them. First we need the pin-outs and the connector code for each side (IF1 or whatever). Again, the idea would be to get a matching connector plug housing and then transplant the wires on one side. Or you could butcher it with butt connectors [shivers in revulsion].
They seem to have played with the format of the EWD's along the years, so what you find may not look like what they had in 2002.
Old Mar 26, 2014 | 03:42 PM
22REFORME's Avatar
i get that i need it.. haha
what i was saying though is that the 97 has that wire in another plug, so i need to depin the wire on that other plug and send the FC wire from the truck plug to it? where does that FC wire go on the engine harness on the 97?
Old Mar 27, 2014 | 10:21 AM
TheDurk's Avatar
I'm not sure I understand the question. On both trucks, the FC wire (green with yellow stripe) goes to the coil of the circuit opening relay. The relays are different, and so the relay pin number is different, but it's the same functional connection (ground side of coil). So yes, I would just take it out of the plug where it is and move it to Pin 14 of E5 which is where the '95 ECU wants it.
Old Mar 27, 2014 | 02:28 PM
  #25
22REFORME's Avatar
I am not using the 95 ecm. The truck is a 95, I am running the 97 engine, engine harness and ecm. The one plug in the ecm that isnt from the harness that matches it is from the truck. The fc wire is in a different plug on the 97, on the 95 ecm the fc wire is in the plug from the truck. Make sense?
Old Mar 28, 2014 | 01:30 AM
  #26
TheDurk's Avatar
Yeah, sorry got turned around in my head after a day off. So the FC wire on the plug from the '95 truck has to be moved to the place the '97 ECM wants it--which is Pin 14 on Plug E5, which corresponds to the 14A by the FC connection to the ECM on the '97 wire diagram. I assume the circuit opening relay that controls your fuel pump is mounted on the '95 truck and not the '97 engine. I'd try and verify where that relay is and where that G-Y wire goes, just to be safe, though. I have no familiarity with that engine.
Old Mar 28, 2014 | 04:01 PM
  #27
22REFORME's Avatar
ok so it looks like the one plug in question going to the ecm is E5 on the 95.5 and E8 on the 97. This is the 22 pin connector that comes from the truck. here's what i have:
E5 on the trucks ecm
PIN FUNCTION WIRE
1 BATT B/W
5 W V
8 ACT L/B
9 SP1 G/O
10 AC1 L/Y
11 STA B/W
12 +B W/R
14 FC G/Y
22 NSW B
E8 on 97 ecm
2 BATT B/W
4 W V
6 ACT L/B
7 AC1 L/Y
8 SP1 G/O
11 STA B/W
12 +B W/L
22 NSW B
Lookin right? the pin numbers not mentioned must not have wires.
FC whatever that is, is the only oddball that exists in that plug on the 95 but a different plug on the 97. FC on the 97 is in the first plug not the last like on the 95.
ok so i moved the wires.these three were the same so i left them be.
11 STA B/W
12 +B W/L
22 NSW B
There was a wire in pin 7 where i moved the AC1 wire, i found something that says this wire is function: SDL , can't find an SDL on the 97 though so i left it hanging.
I also left the FC wire hanging that i pulled from E814 on the 97 ECM because i moved the FC wire from the 95 there. leave that hanging?
Old Mar 28, 2014 | 04:28 PM
  #28
22REFORME's Avatar
Just found E5 20 BK G-W and E5 21 4WD G-W on the 95 but not sure where they go on the 97
this is a nightmare
Old Mar 30, 2014 | 10:24 AM
  #29
22REFORME's Avatar
this is a nightmare
Managed to find these for a 97 tacoma, not sure if the 4runner is the same. For the taco they reside at E5 10 for the 4wd and E5 21 for the BK
Old Mar 30, 2014 | 05:42 PM
  #30
TheDurk's Avatar
Three choices:
1) spend $15 on TIS and get the '97 4Runner EWD's you really need.
2) Check physically for continuity to the brake light switch and the 4wd detection switch
3) hook it up like a Taco and pray.
Up to you.
Old Mar 30, 2014 | 05:56 PM
  #31
22REFORME's Avatar
Three choices:
Up to you.
The TIS site doesn't work for me for some reason... it hangs up when i enter my info.
Old Mar 30, 2014 | 06:26 PM
  #32
22REFORME's Avatar
there are 7 other wires that the 97 ecm wants to be in this plug, from what i can tell they don't exist on the 95 ...
Old Mar 30, 2014 | 09:40 PM
  #33
TheDurk's Avatar
What do they do? Or more precisely, where do they go? Give me the letters and pin numbers and I'll try and help. Maybe you don't need them or they are called something else. It's more important to marry function than color.
Old Mar 31, 2014 | 04:22 AM
  #34
22REFORME's Avatar
ok so i was looking at automatic schematics so there are not that many unaccounted for. there are just two wires not mentioned on the 95 schematic:
E513 TFN R-G
E519 SIL W
Old Mar 31, 2014 | 10:29 AM
  #35
TheDurk's Avatar
E513 TFN R-G
E519 SIL W
Well, not finding the SIL connection on a '95 is no surprise. Remember when I asked you what you are doing about the OBDII port? That is the OBDII data output and of course you won't find one on an OBDI '95 truck. Leaving it off should not affect the running of the truck. You can leave hitching up the OBDII for another day, although I would certainly install one if possible. If it doesn't run right off the bat, pulling the codes would be immensely helpful. Did you pull the port and its harness from the '97?
I cannot find a TFN connection anywhere on the '97 ECU as shown on the EWD. Can you tell me exactly where you saw it? (page, top, bottom, left, right). I wonder if it is the CEL connection.
Old Mar 31, 2014 | 04:45 PM
  #36
22REFORME's Avatar
i emailed u a pdf file, this is where i found the additional info. i still have the 4runner i may just pull the entire truck harness
Old Mar 31, 2014 | 08:33 PM
  #37
TheDurk's Avatar
Got it. That's some document, thanks. Looks like TFN is Auto Only.
Entire? Big job. But definitely get the OBDII port and harness.
Did you make an inventory of the wires physically present in E5 on the truckside harness on the '97? These would be the only ones you have to match up, obviously.
Old Apr 1, 2014 | 04:09 PM
  #38
22REFORME's Avatar
I think then the ecm plug is squared away. Going to double check this.Next problem Is getting all the pinouts for this engine harness to main harness connection.
Old Apr 1, 2014 | 04:46 PM
  #39
TheDurk's Avatar
Good progress, painful as it was. You'll get there.
Old Apr 1, 2014 | 05:25 PM
  #40
22REFORME's Avatar
i can't find these pinouts anywhere...
