Wiring diagram for 3rd gen fog and driving lights
Old Feb 5, 2005 | 04:36 PM
98LimitedCustomized's Avatar
Okay a few people have asked me to do this.... Give me another 20 minutes and I'll do one for reverse lights as well. Okay this diagram tells you everything you need to know to wire up your own set of fogs or driving lights like I did. When I say like I did, I mean that the fogs go on with the dims, and the driving lights go on with the brights, but both can be shut off by a lighted toggle switch. There is really not a whole lot of explaining to do other than note the wire you tap into from the factory headlights for your application. If you're adding fog lights, you'd tap into the red/yellow wire. If you're adding driving lights, you tap into the red/green wire. The wire sizes I put in are SUGGESTIONS, as are the colors of the wires. To me, I think it's nice, especially if you're inexperienced, to use some different wire colors to help you keep track of stuff. Well, enough talk, you need to see the pic... I should also note that since I don't have too fancy of software I hacked up somebody elses picture I found on the net - hopefully I didn't break any copyrights!
http://community.webshots.com/photo/...67293742GvmEHo
Old Feb 5, 2005 | 04:40 PM
Ironmike4x4's Avatar
Sweeeet! And its easy to understand
Old Feb 5, 2005 | 04:52 PM
Gangus2006's Avatar
Well no ˟˟˟˟...I had 30 grounded..
Old Feb 5, 2005 | 04:59 PM
I should also note that this is a diagram that will work with any vehicle, but the wire you tap into from the stock headlights may or may not be marked differently. Also MODS, any way we can throw this up as a sticky for a while, or maybe I should put something in the tech section? It's really nothing brilliant but is something I see people asking about fairly often.....
warrenjcarlson
Jul 22, 2016 11:47 AM
91toybeater
Dec 27, 2015 07:46 PM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
infinityisfive
Jun 16, 2015 06:51 PM
LSUMatt1514
Jun 26, 2002 05:03 AM
