wing window
wing window
I need help with inserting the damn thing
Its not in my book and I cant find it on the search. someone please help
90 4runner
90 4runner
Originally Posted by 86toyota
Are you replacing just the glass or the whole frame, track glass assy?
Originally Posted by chasmc2
the glass with the bottom closing piece attached to it. how does it come out of the door. do you have to take the panel of? or what.
To make it alot easier you should remove or lift up the door panel, wind down window and remove the 2 bolts holding the main window on the track,let it sit in bottom of door, remove the one 10mm bolt for the front window track(that tract is part of the wing window), Like shane said, look for phillips screws on the door post, and then it should come straight up, you'll have to kinda twist it out at weird angles....I don't think you can remove it with main window still attached. Hope that helps.
PNW94Runner
Sep 29, 2015 02:55 PM
tazman1972
11
Sep 28, 2015 10:32 PM
