Will My Gas Mileage Really Go Down???
Old Jan 10, 2005 | 04:39 PM
carose725's Avatar
Question Will My Gas Mileage Really Go Down???
Im planning on putting some 33X10.50's on my stock tacoma wheels and have a question. If i up my tire size will my gas mileage drop a lot or will my odometer just not gauge the mileage right. currently i get about 265 miles to a full tank(2.7L), which isnt bad in my opinion. when i had my 4runner i went from 245's to 31X10.50s and noticed a change in the mileage i was used to getting, but i felt a lot of the change was due to the odometer registering different. Would like some input. thanks all.
Old Jan 10, 2005 | 04:42 PM
jacksonpt's Avatar
Senior Member
Yes, it will drop. how much is hard to say. Your speedo/odo will also be off. I run 33/12.5-15s on my 4runner and I get approx 15mpg, FWIW.
Old Jan 10, 2005 | 05:54 PM
4x4Lamm's Avatar
I switchd from 31x10.50 to 33x10.50 and lost 1.2-2.5 MPG. My spedometer is off by about 4 MPH at 75 MPH, but almost dead on at low speeds according to GPS. Your odometer will not be far off at all.
You will notice a power loss, and 5th gear will get used a lot less, but that look and the ground clearance make it worth it IMO.
Lamm
Old Jan 10, 2005 | 10:02 PM
Keggo's Avatar
so 33x10.5 is a good size? i wanted to stick with my stock wheels as well...
Old Jan 10, 2005 | 10:10 PM
Brendan's Avatar
i like my 33x10.5s. I didn't notice much gas mileage difference at all really. What I did notice though was power loss - especially on hills.
Old Jan 10, 2005 | 10:53 PM
OMINOUS_87's Avatar
Running a taller tire is the same thing as changing the gears in your axle to a numerically lower ratio.
Yall can plug your gears and tire sizes into thos nifty calc-program to see what is up when you swap in taller tires.
www.f-body.org/gears
Old Jan 10, 2005 | 11:14 PM
OMINOUS_87's Avatar
Not to mention weight.
A rough approximation to use, rule of thumb, is that for every 7-8lbs of rotating weight you add to your driveline, it require 5_crank_hp to spin it.
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
