whomp whomp whomp and a sticky caliper?
Old Apr 30, 2006 | 05:52 PM
Localmotion's Avatar
ok....heres the deal:
When I am driving, straight or turning, I hear a sound that is similiar to a whomp whomp whompp. It is more prominent while turning though. I cannot figure out what it could be. Ive read that bad CVs, make a clicking noise. I do have 210K on the original CVs. Would there be anyway it could be a tie rod? I have changed the front drivers side, but not passenger.
Also, I have noticed that when I brake, the truck pulls to the right. It has gotten worse in the past couple of days. When I brake hard, the caliper almost locks the wheel up, so when I come to a stop, the right tire skids. Is there any solution to this? Is something not lubricated? Do i just need a new caliper?
Sorry for the long post and thanks for your adivce.
Old Apr 30, 2006 | 05:59 PM
rimpainter.com's Avatar
Matt-
That sounds like a bad wheel bearing to me. Jack up the suspect wheel and move the top and bottom of the wheel; see if there is play when you do that.
Old Apr 30, 2006 | 06:04 PM
Originally Posted by <96 Runner>
Matt-
which wheel bearing would you think it was?
the tire skids only when I am on the brake sorta hard.
Old Apr 30, 2006 | 06:43 PM
what does replacing a wheel bearing cost? I will check it tmw to see if I have play vertically.
Any other ideas?
Old Apr 30, 2006 | 07:32 PM
I don't know. I could be wrong. I am just going off the experience I had with a Celica All-trac turbo I had. Primarily when cold it would make the same type of noise you are describing here; whomp, whomp, whomp...(increased with speed). I pulled the rotor off and CV out and found a fried wheel bearing.
Again, I could be wrong. It probably wouldn't hurt to push and pull on the top and bottom of each wheel just to check.
Old Apr 30, 2006 | 07:49 PM
yea you are right.
Ill do that tmw and report back.
Old Apr 30, 2006 | 07:52 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
probably not it but i got that same kinda noise in my 92 rodeo but only in reverse somehow (or maybe i didnt hear it going forward over the excessively loud whir of the fan) but it turned out to be a bent u-joint on the driveshaft
Old May 2, 2006 | 06:12 AM
I am pretty sure its the caliper now. It only sticks when I press the brake and I can feel the car kinda dive to the right front.
Does anyone know if I need to buy 2 new calipers or can I just get the front right one? Does anyone have one for sale?
Old May 2, 2006 | 06:29 AM
I need the calipers to be from a 16"wheel.(mainly asking the people who did the tundra upgrade)
ladybugRC
458
Aug 21, 2020 10:41 AM
stanz
Oct 30, 2015 10:33 AM
zanzabar0
Oct 11, 2015 02:56 AM
user 82300
Sep 22, 2015 07:00 AM
user 82300
Sep 15, 2015 05:49 AM
