White Face Guages Installed
Old Apr 11, 2003 | 03:27 AM
WT's Avatar
WT
Thumbs up White Face Guages Installed
Thought I post here too in case anyone dos not check other forums and I know alot are curious on these things, install about a hour and thats with stopping to take pictures.
cost around $50 bucks shipped to my door step
http://community.webshots.com/user/wtconsulting
Click on Guage install album
Old Apr 11, 2003 | 04:11 AM
TStango's Avatar
Nice mod WT!
Did you have to take any of the needles off the guages and if so, was it tricky?
What about the lighting?
Where did you purchase this?
That should be enough questions for now.
Thanks!
Old Apr 11, 2003 | 05:13 AM
AznSky's Avatar
very sweet. Where did you get those from?
Old Apr 11, 2003 | 06:55 AM
Sucellus's Avatar
Nice, I was curious how this mod looked, thanks for the pix. What's the switch for on your dash? Looks like it was part of the mod.
Old Apr 11, 2003 | 07:49 AM
rimpainter.com's Avatar
Very nice. Does anyone know if the manufacturers of these have any without the "PRND2L" under the Tach?
Obviously I dont need that having a 5speed.
Old Apr 11, 2003 | 09:15 AM
WT's Avatar
WT
Okay let me see if I remember all the questions.. install was simple no need to remove old units these just lay on top of them ( Remove small screws and lay new ones in place put screws back in), so needle removal was not needed. there is one thing I'll tell you doe, I may remove the lower area since 2 things were reversed the brake light and I think trans temp but other than that it look fine. ( be sure to check alignment prior to completing install of pod back into the dash.
Were to get them .. http://procarparts.com/store/display...-4RUN-9698-IG6 and @ 39.99 how can you go wrong... ($10 or so shipping)
They also have the silver reverse but I went with these cause of cost and I thought they looked better
They have different lighten effect you can change from the switch someone asked about and from that you can also raise and lower the light intensity since full bright is pretty bright.
Yeah as for the "PRND2L" I don't use them either cause I don't have a light for them there, they still look fine so I say go for it for the price, unless you have money to spend
I guess I need to add more pics too, if it clears up. While I was MOD happy I also added a Revtek 3" lift and crossdrilled rotors and Performace friction pads at the same time last weekend ..
skoti89
Sep 11, 2015 07:46 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
mr_manny
Jul 31, 2015 10:39 AM
Kluch8651
Jul 9, 2015 10:39 AM
