When to lock center diff?
Old Nov 1, 2002 | 08:52 AM
naksukow's Avatar
2001 4runner with locking center diff. When should you lock it? And is it providing equal traction to all wheels?
thanks
Old Nov 1, 2002 | 09:04 AM
Darren's Avatar
Don't lock it on dry surfaces as this causes the front and rear axles to turn at the same speed which is the way a conventional 4x4 works. You'll hear it "chirp" when turning if you do. This causes excessive stress on it.
Use it off-road on loose surfaces: sand, rocks or on snow.
It also disables VSC as you know which you'd then be able to spin your tires in sand, for example, instead of having the engine power cut to nil.
Old Nov 1, 2002 | 09:27 AM
naksukow's Avatar
thanks
Old Nov 1, 2002 | 10:50 AM
WATRD's Avatar
As described above... any time that you are in a situation where increased traction is required.
No. A center locking differential only forces equal power to front and rear. The axle diffs are still "open", thus they provide power to the wheel with the least traction.
There's a great explanation at: http://www.britishpacific.com/offroad/ARB.html
I quote from that site:
"On late model trucks with center locking differentials, the axles are still open (one wheel can spin when loosing traction), so don't be confused into thinking that your late model is a true 4WD because it has a center differential lock. Lock the center differential, engage both Air Lockers, and THEN you're armed for bear!"
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
HaukurU
Aug 3, 2015 02:40 PM
Athansinis
Jul 27, 2015 08:38 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
