What size tires?
Old Feb 5, 2004 | 09:52 AM
kev93p-up's Avatar
Question What size tires?
I recently added some 2" spacers and cranked the t-bars on my 93 truck. I'm planning on adding a 2" body lift soon. What are the biggest tires I can fit with that amount of lift.
Old Feb 5, 2004 | 09:59 AM
EWAYota's Avatar
i'd say with the t-bars cranked (1.5"), and the 2" spacers, then a 2" body lift equally roughly 3.5-4" (correct me if im wrong), 32's would probably be a good fit. might encounter some slight rubbing when in full turn, but would think 33's would be cutting it close.
Old Feb 5, 2004 | 10:05 AM
kev93p-up's Avatar
I was under the impression that you could fit 32s under stock suspension. I figured at least 33s, I could be wroug though.
Old Feb 5, 2004 | 11:56 AM
Flygtenstein's Avatar
33's comfortably.
35's if it was me.
Backspacing is key, look for around 4" as a magic number.
I have 33's with a 1" bodylift and some modest trimming.
Old Feb 5, 2004 | 05:37 PM
Cebby's Avatar
I say 35's. I little reworking the wheelwell probably necessary. How hard do you wheel it? Tires rubbing in the wheelwells and fenders doesn't hurt, just sounds bad.
Old Feb 6, 2004 | 10:54 AM
EWAYota's Avatar
i just re-read your first post and i missed the 2 inch spacers and just saw the body lift and cranked torsion bars. sorry for the horrible input. now that im up to speed, 33s would be a good size, and like they said 35's could fit, they'll just rub (which is a good reason to go higher )
Old Feb 6, 2004 | 11:02 AM
Brendan's Avatar
i fit 33x10.5s with a torsion bar lift alone and it slightly rubs on the mudflaps every now and then.
Old Feb 6, 2004 | 11:13 AM
Denk's Avatar
33's would be nice!!!
not to hijack er anything, what would the metric size be for 32's and/or 33's. More specifically 32x11.50x15?
Old Feb 6, 2004 | 11:31 AM
EWAYota's Avatar
i think 32's are 245/85's....im not sure how that all calculates out. i've looked for a conversion calculator but cant find one
Old Feb 6, 2004 | 11:55 AM
Jackpot2's Avatar
cant be right coz 265's are almost 31" thinks me
Old Feb 6, 2004 | 12:02 PM
Rayday81's Avatar
I'm pretty sure 265/75 is 32x10.5 but I might be wrong.
Old Feb 6, 2004 | 12:03 PM
EWAYota's Avatar
well, i found a chart, i obviously looked at it wrong. i couldnt read it so i was just looking for something that looked remotly close.
Old Feb 6, 2004 | 12:51 PM
Jonathan's Avatar
33's will fit fine. I had a 92 with 33X12.50's with only a 2" body lift for a while and only rubbed every now and then at full turn(I later went up a few more inches) As for the tire size check thistire size calculator it should help
Old Feb 6, 2004 | 12:57 PM
EWAYota's Avatar
good link. all the other ones i found just went from metric to inches.
Old Feb 6, 2004 | 02:09 PM
Denk's Avatar
excellent!! 33's it is.
Old Feb 10, 2004 | 02:56 PM
kev93p-up's Avatar
Sorry for the delay of thanks guys...I've been away. All of the info has been awesome!:drum:
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Yotoder865
Jul 9, 2015 07:51 PM
