what could be the problem (electrical)
Old Oct 26, 2002 | 02:28 AM
david in germany's Avatar
Question what could be the problem (electrical)
whrn i put down the rear window (truck running) the rpms drop turning on the headlights does the same but i turn them off the rpms climb back up. the lights stay bright and the voltage guage drops a little but not extream.
Batterie? wires with bad contact? alternator?
Thanks a million!
David
Old Oct 26, 2002 | 05:43 AM
WATRD's Avatar
Re: what could be the problem (electrical)
Thanks a million!
David
It sounds like your alternator is singing it's death song and is no longer putting out enough amperage. It's putting out enough to run the truck, but not enough to run the accessories too...
Old Oct 26, 2002 | 07:23 AM
alternator
Thanks WATRD
could this be my problem with the bad idle as well? idles good but every 2-3 seconds it dips and smoths out again. but when i am driving there is no loss of hp or anything.
David
Old Oct 26, 2002 | 07:38 AM
WATRD's Avatar
Re: alternator
Thanks WATRD
David
It's possible that would cause that symptom. I would have the alternator checked out for function. If it comes back clean, the next culprit I would start looking for is high resistance on a wire, or a bad connection. After that, it's the battery...
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
