What is this black rubber piece?
Old Nov 30, 2008 | 01:52 PM
txt4r's Avatar
I found this black rubber piece on the garage floor. Its size is like a walnut. It probably fell out somewhere from my '02 Runner, but I have no clue what it is and where to put it back.
I attached a picture here.
Old Nov 30, 2008 | 02:07 PM
flashkl's Avatar
Not familiar with 02 runners, but it could be the dampner like thing that goes under the hood to keep the hood from slamming the fenders, if you know what I mean.
Old Nov 30, 2008 | 03:00 PM
89needsatranny's Avatar
yeah that sounds right.... or it could be part of the battery mount. my
friends father almost died because a mechanic left a piece of rubber just
like that on top of the motor and all it took was one bump in the road for
it to fall onto the throttle and it wedged itself in makin the accelerator
stick. He ruined his trans by throwing it into park while the motor was
revving at 5k+. later that day after finding the piece of rubber he took it
to the shop where they denied leaving it there of course.
Old Nov 30, 2008 | 03:32 PM
txt4r's Avatar
Thank you, guys, for the suggestion.
I checked hood and did not see any missing dampner there.
If this is part of the battery assembly, then where should I check around the battery?
Thanks!
Old Nov 30, 2008 | 03:36 PM
flashkl's Avatar
I would remove the battery and see if theres anthing obviously missing from the assembly
If nothings obvious and its holding the battery tight without rattling or anything, I'd say thats not it either
Old Nov 30, 2008 | 03:39 PM
flashkl's Avatar
Also, look around the garage and look for other things it couldve fallen off of. Unless you were tinkering with stuff on the runner, chances are it didn't just fall off...Toyotas don't drop random parts like some domestics do, especially an 02
Old Nov 30, 2008 | 06:58 PM
97ltd4x4's Avatar
Looks like a bumper for a door/hood to me.....
Old Nov 30, 2008 | 06:59 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
not a hood damper, those have corkscrews on the bottom so you can screw it up/down to get the desired height. could be from a door or something. never seen anything just like that on my '00
Old Nov 30, 2008 | 07:06 PM
littlecommando's Avatar
How big is it?
put it next to a quarter or something
EDIT: I saw that
Old Nov 30, 2008 | 07:16 PM
Last edited by 89needsatranny; Nov 30, 2008 at 07:22 PM. Reason: he answered it(down)
Old Nov 30, 2008 | 07:19 PM
Gerdo's Avatar
You don't need that part. You should send it to me. I lost one.
JK
It is off one of your doors. Look torard the bottom of all your doors and you'll see them and the one that is in your hand.
Old Nov 30, 2008 | 08:11 PM
txt4r's Avatar
Thank you all very much for all the suggestions.
I removed the battery and checked the battery assembly, and found nothing obviously missing there.
It's not one of those hood bumpers, as drguitarum2005 mentioned, those hood bumpers have corkscrews on the bottom. I also checked the door and the rear hatch bumpers -- no, it is not one of those, as those bumpers are much smaller (like peanut size), but this one is bigger than that, like a walnut.
I am pretty sure it came off from my 4runner. Before I found that mystery piece, I did a few things to the runner in the garage: (1) removed the bug deflector; (2) drained and refilled transmission fluid; (3) cleaned MAF sensor and throttle body; and (4) replaced the battery.
Any other ideas?
Old Nov 30, 2008 | 08:19 PM
Check all around it, or other cars that park in the garage because it looks like a door stop kinda thing
it doesnt look important
Old Dec 1, 2008 | 12:48 PM
TEPUI's Avatar
It looks like the bump stops for the doors. Check the bottom corners of your front doors for a little hole (that's where it belongs)
Old Dec 1, 2008 | 02:39 PM
figster69's Avatar
Like TEPUI said above it's goes on the doors. On your Rig it should be the front doors near the lower outer edge. I've had passengers knock that part off while getting out.
Old Dec 2, 2008 | 09:10 AM
txt4r's Avatar
As I mentioned above, its not the door bumper. I checked those on the doors and those door bumpers (peanut size) are way smaller than this one (walnut size).
This one might be a hood bumper, but I am not sure.
Old Dec 2, 2008 | 09:20 AM
cackalak han's Avatar
Instead of using various nuts as size references, can you post the actual measurement?
Old Dec 2, 2008 | 09:28 AM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Maybe he just likes nuts?
Old Dec 2, 2008 | 10:07 AM
flashkl's Avatar
lol, that's going in my sig
Old Dec 2, 2008 | 02:45 PM
mokai's Avatar
Maybe its a bump stop on the suspension.
