Weird idle up
Weird idle up
2004 3.4 L tacoma 80xxx miles
I have an idle up even when the a/c is off.
Is this normal? The only way to stop it is shutting off the fan. Is the truck supposed to idle up w/o a/c for fan speed increase for cooling?
Thanks in advance.
Thanks in advance.
It is the weirdest thing. I disconnected the battery and let the ecu reset and it didnt do it for a few weeks. Then it started doing the non AC random idle up again.
The idle up is identical to the AC idle up.
Does this cause the MIL to trip ??Any non normal idle most often will cause a PO505 code
Have you looked to see if the compressor clutch is engaged when you turn the fan switch on??
How do i check the compressor clutch?
I assume it is on the AC compressor somwhere by the belt pulley?
Blamalam
Mar 12, 2022 07:34 AM
icentropy
Jul 14, 2015 10:23 AM
