The weekend brought a new mod...
Old Apr 10, 2007 | 05:33 AM
mastacox's Avatar
Man Mark, I'm way jealous!
Really excited to see the Dyno sheets...
Old Apr 22, 2007 | 03:39 PM
dijlop's Avatar
sounds like some fun here. anyone have a 22re 4cyl tuned out like these?
Old Apr 22, 2007 | 04:48 PM
Greedy's Avatar
Yeah -Check this guy's out.
http://www.putfile.com/turborunner
Old Apr 22, 2007 | 05:45 PM
profuse007's Avatar
last and most important step is to dyno tune it or else things will be whack out.
post a dyno graph
Old Apr 22, 2007 | 06:22 PM
  #25
YM13's Avatar
Goodness gracious...This makes me jealous because I love horsepower and acceleration but I also love offroading and I was torn in which type of car I should get. It makes me happy to see that there is a possiblity to run high horsepower on these babies....
Old Apr 23, 2007 | 08:58 AM
  #26
midiwall's Avatar
Ummm... raise your hand if you saw this point:
Still need a few things like the IPT valve body upgrade and the stall
DOOOOOOOOD! He's pumping all that power through a stock tranny??? WOW!
Old Apr 23, 2007 | 02:17 PM
  #27
Weasy2k's Avatar
good work man...everything running perfect now?
What MI setup are you using?
Old Apr 23, 2007 | 02:28 PM
  #28
midiwall's Avatar
Perfect is a relative term in my world. It's definitely a boatload of fun, but there's something screwy with my A/FR. I've been through two O2 sensors in the last month and things aren't normal. The truck feels like it's running rich, but the A/FRs show lean. Fuel trims are UP so it looks like it's a A/FR reporting issue. I'm working on it...
It's a Snow controller with a modified Boost-a-Pump. The controller's AWESOME - it's got a MAP on it and the ability to set for what PSI it starts pumping at and what PSI you want full spray at. I built up a simple LED bargraph circuit to monitor the voltage to the pump so I know when it's armed, starting to spray and full spray. Lotso fun.
Gregg (Greedy) and I are looking to get on a dyno in about three weeks. This should be a BLAST.
Old Apr 23, 2007 | 02:35 PM
  #29
Greedy's Avatar
I know what you mean...
Old Apr 23, 2007 | 02:49 PM
  #30
Weasy2k's Avatar
nice! I cant wait to rebuild my s/c and get back at er
Old Apr 23, 2007 | 03:10 PM
  #31
TFJ-4runner's Avatar
Do you have any recent pictures of your engine bay?
Old Apr 24, 2007 | 04:47 AM
  #32
midiwall's Avatar
Who "you"? Me "you"?
I'll get some for ya' this morning...
Old Apr 24, 2007 | 08:27 AM
  #33
midiwall's Avatar
pic of under my hood, It ain't pretty, this truck likes the dirt.
(click for a larger one)
The methanol sprayer hose routing is temp. I need to move that tap closer to the TB.
Old Apr 24, 2007 | 02:48 PM
  #34
Looks good, at what mileage do you think its to late to install a SC?
Old Apr 24, 2007 | 02:55 PM
  #35
midiwall's Avatar
Just about never.
I think I did mine around 130k, there's 165k on it now but then there was also a complete rebuild about 5k ago.
Old Apr 24, 2007 | 02:58 PM
  #36
Just about never.
Really, I guess its not worth it for that much money.
Old Apr 24, 2007 | 03:12 PM
  #37
Greedy's Avatar
Looks like you got a big hole in the top of your hood!!
Can't wait to see what it looks like on the shiny side
  #38
midiwall's Avatar
??? Ummm... which "that much money"? Are you referring to the cost of a rebuild?
I burned a valve probably by my own fault, it had nothing to do with what would be a normal installation. There are MANY people around here with SC's on... I think I'm the only one here that's burned a valve on the 3.4L.
Old Apr 24, 2007 | 03:15 PM
  #39
midiwall's Avatar
Gregg, you gotta stop workin' so much!
https://www.yotatech.com/forums/f39/wa-dudebud-body-work-111557/
Old Apr 24, 2007 | 03:16 PM
  #40
The rebuild, I guess I should of been more clear. When you said never and that you had a 5k rebuild build I assumed the SC had a role in the problem due to high mileage. So I'm assuming 223,000 miles is to much.
