VSC - Is it a problem?
#42
Originally Posted by Duc Hunter
BT17R makes the point perfectly. If his friend in dry conditions was faster on the clock with the aids then I would leave them in. You wont go any faster without them, you may feel like you are but you wont be.
Better tires for the surface you are on will help because TRAC and VSC only kick in when the tires loose traction. The more traction you have because your tires are better suited to the surface you are on the faster you can go before the aids kick in.
I don't the agrument is "should we do it"....rather "how to do it".
If people prefer to have control over the vehicle, they should be able to.
The system may do a better job in some instances but the system may overcompensate as well.
Completely up to the driver's preference....and many want it removed.
I don't have VSC or TRAC and mine drives just fine without it.
No reason it can't be a pushbutton system rather than fulltime IMHO.
#44
2wd models have a button on the dash to disengage it. Now doesnt that make sense. I buddy treated me to a standing still smoke party, while I was in my 4x4 03 sr5 crippled by technology 4rnr. I in fact almost hit a telephone pole in the snow because of VSC when it locked and didnt allow me to hit the gas to pull out of a slide.
#45
I cannot believe that this thread is still lumbering along with no solution. After reading everything I could about the VSC, I decided that when traction is the slightest bit questionable --- wet roads, sandy roads, snow or ice, I will engage the 4WD. The mfg says it will not hurt and the 4WD in our late model trucks is actually like AWD. If something happens, they can fix it.
#46
*IF* you have it... like i do... DO NOT lock your center diff if your in 4wd on concrete... but you prolley already know that...
after a while with VSC now, i just come to live with it, after comming back from Naches pass I have no problem, i guess it all comes down to it, it depends on WHY you want to disable it...
#47
#49
Originally Posted by johnyrrr
sometimes you just want to spin tires around in the gravel like the Dukes of Hazzard. I HATE not being able to get a little sidways in the snow if i want.
Yea... that I agree with lol...
#50
hahah.. true!
this past winter, i saw this parking lot by a train station hadnt been plowed yet (we'd gotten like 8 inches or so).
i stopped, pulled a u-turn and drove in there (i was the first!) and tried to skid out a few times, to no avail. i mean, yea, it slid a bit, but i lost all power to the pedal and the fun stopped.
#51
Originally Posted by MTL_4runner
This seems to be the concensus for disableing it so far.
"There is a separate switch...CENTER DIFF LOCK. I think when you off-road, you should lock the center diff most of the time anyway. Putting another switch will just be more confusing.
Guys, it is not that hard to understand how ATRAC works! You CAN turn off the "dethrottle" function by locking the center diff. This is EASILY done by pushing a button. "
#52
Here's a lengthy YT thread I started many moons ago about A-Trac/VSC. After much investigative work, I still haven't found a good way to defeat the A-Trac system (not that I've tried much lately). I did find that the A-Trac/ABS system seems to have redundant electrical paths within is component circuitry, and therefore was never able to completely kill it. Disconnecting one relay seemed to forced the A-Trac/ABS system to use another (likely designed that way to prevent a complete ABS system failure). I found I could reduce the intensity of the ABS/A-Trac pulsation, but never totally eliminate it.
My comments regarding disabling A-Trac are on page 2, second to the last post (username "hillbilly") in the thread MTL_Runner referenced.
Here's another good thread to read:
http://www.toyota-4runner.org/showth...s=&threadid=12
#53
I found a temporary way for my 03. I'm not sure that it will work for yours also but it's worth a shot. In the engine compartment fuse box, look inside under the cover for which fuse it is, remove it, start the vehicle and let it run for about 30 sec., turn it off, replace the fuse and it should be disengaged for about 1 or 2 starts. I think after a few starts, it just resests itself. I know it's a pain to get under the hood everytime to dissengage it, but this way you don't cut into any wiring! Good luck.
theking11863
Mar 19, 2016 09:36 PM
