Valves tapping....
Old Sep 27, 2012 | 05:31 PM
RMSlayer's Avatar
Valves tapping....
HellO. Yota tech!
My valves have started to tap..... Oil was a bit low, it was just above the lower indicator, no oil light on. So I added about a 1/2 quart. I have had the timing belt done recently..... Wondering what's going on? Any ideas, thoughts on what could be causing the tap?
Thanks for reading this
-Stefan
Old Sep 27, 2012 | 05:53 PM
Spazzcdnm's Avatar
What motor is it and how long since the valves have been adjusted. If its been a while, It may not be a bad I dea to go in and re-adjust them. Really easy to do once you know how.
Old Sep 27, 2012 | 06:07 PM
RMSlayer's Avatar
Thanks for the response Spazzz,
I bought the 4runner, 4 years ago, and have not adjusted the valves since. It's a 3.4 5vz-fe.....
Old Sep 27, 2012 | 09:21 PM
Spazzcdnm's Avatar
ok.... I have ZERO experience with the 5vz-fe... a 22re is super simple to adjust... the 3.4 however.... not positive, but I am fairly certain that is a whole nother story....
Old Sep 28, 2012 | 04:18 AM
Texas_Ace's Avatar
Is the sound new? Or just new to your ears?
The injectors are pretty loud and are easy to get mixed up with valve tapping. Put a stethoscope on the injectors and see if that is what you are hearing.
As long as the oil was on the dipstick that should not be the problem unless you were making high speed tight turns or heavy angles off-roading.
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
