Urgent Help!! Ignition Locked??!!!
Old Oct 9, 2003 | 11:19 AM
Cebby's Avatar
You can probably buy just the one, but then your ign key would be different than your other keys (I think). I bought a whole set for my 4Runner and it was around 2 bils.
Old Oct 9, 2003 | 11:50 AM
growinseed's Avatar
With your VIN you can get the key matched by the dealer or the key code from the original key and a lock smith can match the new tumbler to your key. I had a damaged door luck, unsuccessful break-in, replaced and rekeyed for about $50.00. If I remeber right a new ignition cylindar is around $150.00.
HTH
Nathan
Old Oct 9, 2003 | 11:54 AM
Shane's Avatar
Getting a lock cylinder key/vin matched doesn't always work out, your old keys are worn and may not work in the new cylinder. Just FYI...
Old Oct 9, 2003 | 12:01 PM
KING's Avatar
ROTFL LMAO!!
200 DUCKETS FOR A NEW CYLINDER??!!
Forget it............ I'm walking.
Old Oct 9, 2003 | 01:05 PM
  #25
Detcord's Avatar
Originally posted by KING
THANKS ALOT!!
Since I cant do nothing from where Im at, I called a towing thingy to come pick me up..........
But ill definitely buy that as soon as I get home and have transportion to get that
i wonder if stuff like wd-40 workds..........??
WD-40 is only good for making things rust. You spray kerosene on anything that has an oil film on it and you just made it very unoily. While the WD-40 is wet its slick, once it dries....you are fuct.
Old Oct 27, 2015 | 10:19 AM
  #26
Kevindow's Avatar
Ignition Cylinder Locked
I can't turn my key to start an 86 truck. I have tried shaking the wheel while turning key, I have tried pulling on wheel while pushing release button and turning key, I have tried hitting cussing and about everything I could do but no success.
So I removed the steering column covers. The manual gives direction to replace ignition cylinder, but step 2 says to turn the Key to ACC before removing cylinder. Unfortunately I can't do that.
Any suggestions?
westonian18
May 1, 2020 06:38 AM
Flossy
Aug 5, 2015 05:14 PM
TDonkey
Jul 26, 2015 10:14 AM
94whiterunner
Jul 12, 2015 07:15 PM
