Upper nut for L rear shock tower
Old Jan 20, 2005 | 09:57 PM
travelinman's Avatar
Question Upper nut for L rear shock tower
I'm about to install the 1" PP springs with the Bilstein shocks. I was looking around down there tonight planing my attack and I noticed that the top nut on the Left Rear shock (top of the shock tower) is VERY difficult to reach (gas tank, e-locker harness, brake cables...etc in the way).
For those of you who have removed your own shocks, how did you reach that nut ?
I'm taking the springs out too, so I think I may be able to reach up there once the left spring is out, but I can't tell.
Help...please...
Old Jan 21, 2005 | 08:18 AM
It is a tight space but it can be reached with a bit of trouble.
Use a deep socket 14mm (if stock) on a small rachet, and a use an open wrench to hold the top of the shock from spinning (there should be a hexagonal fitting on top).
Good luck
Old Jan 21, 2005 | 11:35 AM
Bennito's Avatar
I went deep socket on top and channel locks on the shock (body).
Old Jan 21, 2005 | 11:38 AM
rimpainter.com's Avatar
Dont forget to soak it in PB. That will help.
Old Jan 21, 2005 | 12:08 PM
grams72's Avatar
Vise grip on the top nut, Pipe wrench to turn the complete shock.
Old Jan 21, 2005 | 12:38 PM
Thanks everyone! I'll try all of the ideas and let you know which worked best for me...
Old Jan 21, 2005 | 12:50 PM
ASU4runner's Avatar
It's really easy if you install a 1" body lift!!
88sasturbotoy
Jan 30, 2026 01:57 PM
lledwod
Aug 30, 2016 01:03 PM
Whatever123
Sep 30, 2015 12:12 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
