Tuneup suggestions
Old Feb 17, 2003 | 12:53 PM
Tuneup suggestions
My rig has 82k miles on it, and probably has never seen a tune-up; I bought from a dealership at about 65k miles, so it was probably a lease return. I have not pulled the plugs to find out how bad they are but lately I've been noticing a dramatic decline in mileage and a bit less performance, so I'm going to have a "fix the rig" day and just freshen everything up. Here is a list of all planned, however if anyone has cheap or minor (hopefully both, but I'm not opposed to wrenching as long as it isn't expensive parts-wise) recommendations for things I can also do, please add them!
- New spark plugs, Toyota recommended (dual-tip I believe?)
- New PCV
- Check-out vacuum system, may replace hoses. At 82k some might be cracked on the ends now.
- Thoroughly clean out Throttle Body with carb cleaner and toothbrush. ***DO I NEED TO REMOVE FROM INTAKE FOR THIS, AND IF SO DO I NEED TO RPLC GASKETS?
- Verify condition of other hoses, lines, etc. Replace as necessary.
- Belts all look ok, no need to touch them yet.
- New fuel filter
- Air filter is K&N, recently cleaned (excess oil wiped to protect MAF). Replacing with Amsoil soon anyway, but I do not believe this is the problem.
I have also noticed a very sporadic idle issue where it will drop to about 300RPM and stumble a bit, but touching the gas acts normal (i.e. not a missing plug). Could this be a dirty throttle body, some issue with vacuum system (or PCV), or ??
Thanks for the input!
Old Feb 17, 2003 | 01:03 PM
rimpainter.com's Avatar
Re: Tuneup suggestions
Good idea.
- New PCV
Its very rare that these need replacing. You should be able to clean it out with the carb cleaner and a little shaking until it sounds "loose"
Good idea
Be careful with the carb cleaner. I would spray it on a clean towel and go around and around the TB until its clean. No you do not need to pull the TB off, and if you did you would want to replace the gaskets.
Good idea
Good thinking, but the only way to really tell if they are ok is to pull them, so you might as well do them while you are in there.
- New fuel filter
Never done this one. I thought it was an in tank filter...
Definetly get an Amsoil!
See if its still there when you are done with all this work.
Old Feb 17, 2003 | 03:16 PM
FattyCBR's Avatar
I would not use carb cleaner for cleaning the throttle body, you should be able to find fuel injection cleaner at your local auto parts store.
You can pull the TB off not problem, just make sure you do not undo the two hoses underneath it that have clips on them, they route coolant through the TB to warm it up. If you do remove it, you do not need a new gasket, it's metal and is infinitely reusable. In fact I would recommend removing it so you can clean it better because the back of the butterfly is what gets very dirty.
Good luck
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Iceman4193
Oct 16, 2015 10:50 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
the_supernerd
Oct 1, 2015 09:20 PM
