Trouble shooting guage lights
Old Aug 8, 2003 | 12:18 PM
lbb-1's Avatar
I did the white face guage mod two month ago with no problems since.
last night lights wont come on guage cluster.
Might be fuse not sure which one.
Anyone else experience this same problem?
Thanks
Old Aug 8, 2003 | 03:59 PM
butnut's Avatar
Try checking where you made your connection to tap in for your light source.
Old Aug 11, 2003 | 10:41 PM
lbb-1's Avatar
larger fuse
Turns out is was a fuse in the driverside kick pannel.
It was a #15, replaced it the other night and it blew again...
Can I put a #25 or something larger and not mess anything up//
Thanks
Old Aug 11, 2003 | 11:12 PM
butnut's Avatar
I would'nt. If it blew twice, something is shorting. Follow every wire from the gauges, make sure nothing is cut or pinched...my dome and floor lights shorted out...it was the metal clip on the kick panel, nicked one of the wires when I put it back...kept blowing the fuse too. Good luck.
Old Aug 12, 2003 | 08:41 PM
lbb-1's Avatar
Wire Question
Looked at everywire no nicks that I saw maybe need to look harder?
Perhaps a related cause. I did cut into two blue wireson the drivers side trying to determine fuel pump wire.
At anyrate I put those two wires back together with the swrew cap type connector/ Maybe I shoulkd have used splade blade instead..
what do you think
thanks
Old Aug 14, 2003 | 01:21 AM
butnut's Avatar
Wire nuts are'nt the best with the thin auto wires, solder and heat shrink is best...butt connectors (the good clear vinyl ones) are fine too. I dunno, did you check to see if your dimmer switch is turned up? Gotta recheck all your connections, trouble shooting is a bitch....
AkitaDog
Sep 1, 2015 08:05 AM
defrag4
Jul 31, 2015 10:50 AM
kirkrunner
Jul 27, 2015 07:59 PM
sabine
Jul 18, 2015 03:59 PM
shisha1999
Jul 13, 2015 11:09 PM
