Transmission won't hold in any gear
1998 3.4 and a340f automatic in my '95 4Runner. I can crank the auto trans lever down into 1st, but it will shift out just like normal. Won't hold in 1st or 2nd. O/D lockout works. Any ideas?
Thanks for the input. I wired up this swap myself, so another guy in the 3.4 swap section suggested some wiring to look at. After looking over my adapter harness I didn't wire up the L and 2 on the transmission to ECU. It's an electronically controlled transmission and L and 2 have their own positions in the ECU plug at e12-1 and e12-10. The linkage is all good, but apparently it needs ECU input to hold in 1st or 2nd. I'll try to report back, but it's looking electrical, and something I caused.
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
