Transmission not shifting
Old Dec 21, 2006 | 08:58 AM
881stGenRunner's Avatar
My brother has a 97 4runner 2wd auto and there is something wrong with the transmission. We pulled into work today and when i got in the drivers seat to go get some food i put it in R and did nothing. You can feel it drop into the proper gear, but there is nothing. I tried to push it backwards in N and it seemed like it was in P and wouldnt move. it is stuck at where we work right now and if anyone has any suggestions they would be greatly appreciated. O btw what is the name of the tranny. I have already looked on 4x4wire and it doesnt give the name for 3rd gens. Thanks again.
-Brandon
Old Dec 21, 2006 | 09:22 AM
mt_goat's Avatar
Kind of sounds like maybe the shifting linkage bolt/pin fell out. Look under the truck and verify that the shift lever on the tranny is actually moving with the shifter.
Old Dec 21, 2006 | 09:30 AM
gpcollen1's Avatar
Are there any other electronic or vacuum controls on this tranny? I ask only b/c these have been issues on other vehicles but i have no idea waht makes our trannys tick??
Old Dec 21, 2006 | 09:41 AM
mt_goat's Avatar
Well even with the tranny out of the truck sitting on the ground the shift lever will move it in and out of P and N. There is no power needed to do that, which is why I was thinking his shifter (inside the cab) is not moving the shift lever on the side of the tranny.
Old Dec 21, 2006 | 09:46 AM
eric-the-red's Avatar
Electronic controls yes, vacuum no. But the electronics only control shifting after it's in D. Going from P to R to N etc is mechanical, controlled by the lever. And your 97 has an Aisin-Warner A340 series tranny, I think a 340H.
Old Dec 21, 2006 | 09:51 AM
mt_goat's Avatar
The A340H is the 4wd model IIRC.
Old Dec 21, 2006 | 10:14 AM
Thanks for the help i will try it out.
Old Dec 21, 2006 | 11:00 AM
mt_goat's Avatar
It could be that the adjustment bolt for the shifter linkage is loose and let it slip out of adjustment.
Mine looks like this:
Old Dec 21, 2006 | 12:29 PM
Correct, I didn't notice it was a 2wd. They're almost non-existant in Canada so I tend to assume all 4Runners are 4wd. I think it's a 340E in the 2wd.
Old Dec 21, 2006 | 12:32 PM
Well i think i may have mislead a few of yall. When it goes in the gear it will catch and shift hard into the gear then shift hard out of gear. Very jerky
Old Dec 21, 2006 | 01:59 PM
a few more things we found out today once we started messing with it; will definately shift into R but there is something in the tranny restricting it, when in N it will only go fowards and you cant push it backwards, when in D it will start in 3rd gear and will not go to any other gears except for OD. Even if you put it in L or 2 it will not do anything. We are gonna have to take it to a tranny shop and see what is up with it.
Liadrin
Apr 25, 2022 02:54 PM
crammit442
7
Nov 29, 2017 12:30 PM
mskalmus
May 28, 2017 07:51 AM
Liadrin
Sep 1, 2015 06:44 AM
Gio8
Aug 27, 2015 12:14 PM
