Transmission lines for external cooler?
Old Mar 15, 2010 | 09:02 PM
twitchee2's Avatar
So im doing some stuff ive been wanting to do a for a while finally found some time. The big one is my transmission. Im installing a external cooler I got out of a 1-ton dodge so im making it work. my question is what kind of lines do i need to get? Can i just use some fuel line or vacuum line or something else? Im going to be dropping the pan and changing the filter in there. Other then that im going to redo some wiring for my lights and things of that nature, then doing the bagel mod. Anything else i should look into?
So main question is what kind of line should i use to the trans cooler?
Old Mar 15, 2010 | 09:09 PM
DeathCougar's Avatar
Use transmission cooler line, of course.
It needs to be line made for oil. vacuum line will not work.
Old Mar 15, 2010 | 09:19 PM
twitchee2's Avatar
that makes things simple....way to simple.... thanks
chuckross1957
Jun 28, 2019 10:19 PM
4x4-runner
Aug 30, 2015 08:55 AM
this_guy
Jul 31, 2015 01:27 PM
jjrbus
Jul 17, 2015 07:06 AM
Snort
Jul 9, 2015 03:58 PM
