Transmission Bolt Size, HELP!!!
Old Jul 22, 2005 | 05:04 PM
AKennedy87's Avatar
So I thought my clutch was bad but it ended up being weirder but easier. Apparently I didn't torque down some of the transmission mounting bolts hard enough... so 3 on the bottom drivers side are gone. This is making everytime i push the clutch down seperate the engine and transmission instead, probably like 1000lbs seperating them or whatever it is.
But...
Does anyone know the bolt sizes for these mounting bolts? I think there are 2 large ones and one small one.
I don't know exaclty if there were nuts and bolts or just bolts but if they are coming out i may just get a long one and put nuts on the other side.
But I don't really want to drive it to the store to find out the sizes so if anyone knows the sizes it would be excellent,
Thanks,
Alex
Old Jul 23, 2005 | 01:22 PM
SlimJim248@earthlink's Avatar
If the head of the bolt is a 14mm, the thread size should be 10mm x 1.25. if the head is a 12mm, the thread should be 8mm x 1.25. that should be your two sizes.
kgcwb44
Jan 29, 2023 10:02 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
