Trans Output shaft Brass bushing?
Old Apr 8, 2010 | 09:24 PM
traxxi2003's Avatar
Ok, After waisting money on a new driveshaft (new u-joints & balanced), It looks like my 1997 2WD 4Runner SR5 has a bad "Transmision Output shaft" brass bushing. Has anyone replaced one of this before? How do you do this? Thanks!!
Old Apr 8, 2010 | 10:41 PM
PismoJoe's Avatar
Factory Service Manual 95.5-2004 Tacoma
http://www.ncttora.com/fsm/1996/96_r...searchable.pdf
Scroll down a little more than half way, pg TR-33
Search the FSM next time
Old Apr 9, 2010 | 10:49 PM
traxxi2003's Avatar
A340F output shaft Bearing/Bushing Bad
Thank you "Pismojoe" for the FSM link. Have you had to change one of this before? Is this a common thing to fail on this transmissions? Thanks!
Old Apr 10, 2010 | 06:27 AM
exrunner's Avatar
Were you having vibration issues?
Old Apr 10, 2010 | 04:14 PM
traxxi2003's Avatar
Well, It all started right after I installed a 3" lift. First, started to make noise only when driving between 50-70 mph, and only when there is no load on the driveline. Example; when using cruise control, or when barely pressing the gas to maintain a constand speed. Anyway, it first started as anoise now it started to vibrate. No to violent.
Old Apr 10, 2010 | 05:21 PM
PismoJoe's Avatar
I don't think I've ever had this bushing fail, but when we pulled out my buddys w56 to replace the bearings, we threw a new one in while we were in there.
Since you said that it started after you put your lift on, your pinion angles could be off. Check out "4crawler's cheap tricks" to check your pinion angles. There's a lot of good info info in there, and its laid out very well by roger.
Just my .2 but it should help!
Old Apr 10, 2010 | 06:34 PM
exrunner's Avatar
Originally Posted by traxxi2003
Well, It all started right after I installed a 3" lift. First, started to make noise only when driving between 50-70 miles per hour, and only when there is no load on the driveline. Example; when using cruise control, or when barely pressing the gas to maintain a constand speed. Anyway, it first started as anoise now it started to vibrate. No to violent.
That sounds exactly like what mines doing. I thought my tires might be out of balance as my rear driveline is fine.
glowz825
Jan 25, 2022 09:28 AM
he's gone
7
Dec 3, 2019 07:08 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
JAmdor3
Aug 11, 2015 10:53 AM
andrewtexas123
Jul 14, 2015 04:29 AM
