Trans Cooler Installed..
Old Dec 4, 2004 | 04:36 PM
WT's Avatar
WT
Well last weekend was the supercharger so figured I should get a trans. cooler installed so that was todays project well its mounted just have to plumb up the lines in the morning, Also while I had the skid plates off cleaned them up tossed on a coat of bedliner spray paint, that stuff dries fast and looks good so far.
http://community.webshots.com/album/227129933tQOjPD
Old Dec 5, 2004 | 05:04 PM
WT's Avatar
WT
Updated the album with more pictures from when I finished it all up today..
Old Dec 5, 2004 | 05:30 PM
justinh's Avatar
did you plumb it into the factory one? like through the factory one then a new line through the aux. one, then back to the tranny?
Old Dec 5, 2004 | 05:38 PM
UNR.Grad's Avatar
You jsut tap the return line to the tranny.
Old Dec 5, 2004 | 05:40 PM
WT's Avatar
WT
Yeap just tapped to the return side of the Radiator was alot easier than I thought it would be, took longer to mount the unit
Old Dec 5, 2004 | 05:43 PM
justinh's Avatar
was there enough excess or did you have to get a new short hose to run to the input on the aux and then use the original return line?
Old Dec 5, 2004 | 05:57 PM
WT's Avatar
WT
This kit come with pone piece about 3' long that worked fine for one and then I baught a second piece came pre-packaged about 3' also. and I also got some plastic seath to protect it around the corners. There are 2 nice writeup on the site here check them out.
kawazx636
Oct 6, 2021 03:03 PM
scott90
Oct 4, 2015 09:21 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
tshort48
Sep 27, 2015 01:04 PM
Odin
Sep 26, 2015 06:56 PM
