trade power for mileage
I have a 3.4 L V6 and for most uses provides more than enough power. I was wondering of a way I could decrease the power so as to get better gas mileage. My initial thought was what if I disconected a spark plug wire or two, then I'd be working with less cylinders. Something tells me that wouldn't work though. Can anyone tell me why and what would happen if I did? Does anyone have any other suggestions on how to trade power for mileage?
if you unplug the spark plug wire, it will shake, and be rather violent, and the injector will still pump fuel in but just not get power from it w/ out the spark. To actually achieve your goal, you would have to unplug the injectors, but it will still run like crap and shake. Honestly your best bet is to keep the truck in the best mechanical shape you can. Synthetic fluids will help reduce some friction and free up some MPG, proper tire pressure (or maybe a bit higher) will help a LOT, electric fan will help as well. And of course if you really do that much driving .. buy a Yaris or Corolla or something for your daily commute, and save the 4runner for when you need it to do what its good at.
Case in Point, little things do add up.
I figured it was bad to unplug the spark plug wires, hence why I asked first. I do a lot of the little things already to improve my mileage, but was looking for a bigger change by sacrificing something else. I currently get 19-21 mpg (22 on a really good day). However I've been doing a lot more driving lately.
I could get a Prius which would get me about 45 mpg. If I drive 19k miles a year the Prius would take 422 gal and the 4Runner would take 950 gal. Thats a 528 gal difference. Which is about $1000 at current gas prices. A Prius will cost me a lot more than $1000 and depreciate more than that so I'll stick with the 4Runner.
I calculated the difference between driving my Camry at 30 MPG and driving a 4Runner (20 MPG) for me at $4.00 / gal for gas and it was like $30 / month. Hence, why I bought one.
Before i moved to CA i had a winter beater Corolla (84 FWD model) that got in the 30-40mpg range depending on how you drove, and that cost me like $300.... almost wish i would have brought it w/ me.
Tape a block of wood to the back side of your skinny peddle LOL.
Seriously do everything you can to keep it in closed loop, which basicly means never going over about 80% throttle. Don't change the air intake, stock will be best for keeping it in closed loop and 14.7 A/F.
leave it alone. If you buy the synthetic you are paying more for oil. Not quite twice as much but more. You have to change the oil every 3 k to see benifits from it. maybe the gear oil would be a good idea, though.
buy yourself a 95ish boneville or buick century. I had one that got 32 MPG on trips and 29 in town. good power and CHEAP. 1500 bucks and your set. kinda a grandma car but seriously when going on the cheap it doesn't matter. Or find an old (95-98)turcel. just as good, reliable, and cheap. just my .o2 not an expert here.
Les power doesn't mean that you will get better mileage. If a vehicle is under powered it will get bad mileage. The engine will have to pull harder, requiring more gas, to get moving and hold speed. Big engine cars can get good gas mileage if you drive consertively.
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
Tacoma1313
Aug 17, 2015 05:44 PM
anniesball
Jul 30, 2015 12:14 PM
