tire size help
Old Mar 11, 2007 | 09:31 AM
Guerrero's Avatar
tire size help
I need to replace my tires, and there is a hot sale for BGF 33 muds that if I don't take avanage of it now, I may loose the deal.
My question is, I'm running 285/75/16, and the tires I'm looking at are 33x12.5x16.5 how much wider (in inches) are the tires?
I'm worry that they wont fit, with the 285/75/16, I only have a 1.5" from the tire to the control arm.
Old Mar 11, 2007 | 09:35 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
11.2 inches currently (285 mm = 11.2 inches) and the new ones are 12.5 inches wide. do you have any lift? if not, theres a real good chance they'll rub
not to mention you have 16" rims and the BFGs say 16.5" rims (never heard of a 16.5" tire...)
EDIT: on second though you might be ok given that you already have 33s and youre only gaining about .7 inches on either side...
Old Mar 11, 2007 | 09:49 AM
Guerrero's Avatar
yes, I have a lift, my problem is the back spacing of my rims... I'm actually running a 1.5" wheel spacer to fit the 285s.
285s without the 1.5" wheel spacer:
The 16.5 may be a error, I've never seen 16.5 neither
If it's only .7 inches, I may be ok.
Thanks
Old Mar 11, 2007 | 09:50 AM
d0ubledown's Avatar
they'll be fine. only about an inch wider = half inch wider on the inside + half inch wider on the outside give or take a bit
do they come with rims? you'll have to get some new ones if they dont which may or may not kill the deal...
Old Mar 11, 2007 | 09:51 AM
d0ubledown's Avatar
16.5's do exist. they're not as common, which means tire selection is limited. you should be able to find a 16.5" rim for a chevy fit, just double check the bore diameter...as the chevies are a bit smaller. some grinding may be necessary, if youre comfortable with that.
Old Mar 11, 2007 | 09:58 AM
Guerrero's Avatar
The sell is only for the tires, I never thought there was a 16.5 rim
He has a F250...
Thanks
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
