Tire Rubbage
Tire Rubbage
For the past couple of wheeling trips I've done I've been hearing a sound of something rubbing when the suspension is flexing but I never could see any evidence of where it was rubbing at.
We'll today I've found the problem thanks to some mud:
Driver's side rear
So at full stuff the driver's side rear tire rubs the inside of the fender. The passenger side doesn't rub when stuffed.
What would cause just the drivers side rear to rub?
Driver's side rear
Do you have a panhard drop or extension?
Could be that since you're lifted the axle moves towards the passenger side thus changing where the tire ends up once it is fully compressed.
Also, check for bent lower links. Passenger side could be bent thus pushing the driver side back. Or hell, bad bushings could do the same thing.
My 2 cents..
My 2 cents..
My 2 cents..
My 2 cents..
Bushings? I have to check on that one.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
