Tips For Better Gas Mileage
Speaking of driving too fast on an interstate, here in WV the speed limit is 70 and most people push 80. Not good for gas milage at all.
I do agree that the biggest savor of all is to lighten up on the peddle. Slower , smoother take offs. When climbing hills and your doing a steady 50 as you climb that's fine, but if you hit that peddle and shift it again to gain speed the gas gits sucked down the drain in a hurry.
Kind of reminds me of that song that the group "Alabama" had out a few years ago "I'm in a hurry and don't know why" ,Lol. Mike
Originally Posted by Nick Cuban
i hope you drove the loner car like a bat outta hell, the only time i had a rental car (mazda 626) my friend had one at the same time (chevy cavalier) and we would drag race and go like 40mph and pull the E-Brake and do 180s, powerbrake, slide on gravel roads etc. loner cars are an excuse to break the law and not go to jail
I cant really add anything, but try removing your crossbars on your factory roof rack.
I (still need to do it - dont have the torx bit it takes) bet it'll save 1 mpg or so.
Use the AC when on the highway. Windows down in town.
Or, if you're really serious, take the rear bumper, all the doors off, remove the spare, take out all the interior except the driver's seat, remove the speakers, etc etc etc.
Then, you'll have lost a ton of weight, and it'll be faster too!
#25
Matt
#26
Originally Posted by celica
Dont forget to remove the windsheild and the back window to let the air flow through and reduce drag. Also you can put the tires froma model T on the truck, they are narrower, lighter and therefore less energy to get them to roll.
Matt
Matt
Also, if most of you don't know, a bugshield can take away 1mpg, and a bike rack 1mpg or even more.
Yes, I have both, and aren't removing either.
#27
not my fault you have to fix the cars, sorry that you do. and i wasnt bragging about drag racing. i didtn say i was so fast and won money or anything of the sort. you seem angry
love not hate <3
and the break the law and not go to jail was sarcasim
love not hate <3and the break the law and not go to jail was sarcasim
#30
I was thinking... How much of a difference would it be if you were to modify the radio antenna so it does not stay up all the time. Or if you were to get a shark fin antenna instead of an antenna that goes up and down. I'm not sure how much drag is caused by an antenna.
#32
Originally Posted by EWAYota
Bump Draft.....saves you gas and you can go faster!
#33
Actually that was just do to it being the best photo I could find.
I pull for the salty vet, been a fan of his since I could remember, just glad to hear he's coming back for one more full-season, though he's gonna have his hands full with a full time cup ride, some truck series and of course Busch series.
Then once he's done, my Busch favorite and now Nascar star Carl Edwards will be the guy I pull for.
#34
Dude, I understand...Don't want to Jack this thread...I'm with YA! Send me some Email!
#36
Hold a bug shield out the window at 65mph... okay, that won't work...
Stick your hand out the window at 65mph, flat to the wind. Feel the pressure? A bug shield is roughly 10x bigger, and on SUV/pickups will cost you 1 to 2 mpg. Now take your radio antenna off and hold it in your hand out the window at 65mph. Hardly any resistance there. Isn't gonna matter much.
For SUVS roof racks and bug shields and roof mounted light sets each cost 1 to 2 mpg. Big racks like a Conferr cost 3 or more mpg.
For cars, roof racks, bug shields (on cars?) air dams, rear window louvers (not common these days thankfully) rear spoilers, bike racks, etc each cost about 2 mpg. None of these items aid aerodynamically unless you actually get up to 180 mph, they only add drag at normal speeds.
The spot on the curve where the aerodynamic drag for a car or light truck really begins to use up engine power is roughly 60 mph. As you go above 60 the force of wind pressure on your frontal area and the effect of form drag really begin to add up, and it goes up exponentially (inverse-square IIRC.)
So, keep the engine tuned properly, peel off those add-ons when not in use, maintain proper tire air pressure, and slow down and you can see a big difference in your mileage.
#38
accelerate BEFORE you get to a hill, and once on the hill, try to keep your tach at a steady 2.5 to 3. extra shifting means extra gas consumption. not much help; i think every other tip has been covered, but i get about 320 mi. per tank on an 02 sportrunner. i've also heard that constantly keeping your tank above half full relieves some of the stress of your fuel pump thereby saving fuel, but i don't know about the credibility of this one. anyone else heard of that?
#40
Most of the drag of a larger vehicle, like an SUV, is found at the rear of the vehicle and not the front. That big ole boxy rear of an SUV, creates a negative pressure area back there, as the air flows over and around the vehicle. The larger and boxier the rear is, the worse the negative pressure is. Find you a wind deflector (no silly ricer boy wings!) off of the back of an old station wagon or some other small SUV and set it up to direct air, flowing along the roof, down into this negative pressure area, thereby reducing the size of the negative pressure area.
Run your tire pressure on the high end of what the manufacturer recommends and on the high end of what you can tolerate. This reduces rolling resistance.
Make sure your brakes are properly adjusted and not dragging excessively.
