Timing belt and its effect on fuel economy
Old Dec 26, 2005 | 11:35 AM
Weasy2k's Avatar
as it should be...those T-belts are solid even after 80-90k miles
Old Dec 26, 2005 | 01:11 PM
blown4runner96's Avatar
Originally Posted by MTL_4runner
That was Toyota's criteria initially (people on YT didn't make that up).....they later revised it to be 90k across the board.
Yeah I know our old checklists for services still stay they recommend 60K mile t/belts change 95 and older and 90K for 98 and newer... I love it can we be more vague and leave out any more info... LMAO
Either way I've seen t/belts on 5VZ-FE motors go well beyond 100K, although I've also seen them pop a little over 100K... depends on how much of a risk taker you are
Old Dec 26, 2005 | 02:52 PM
Toysrme's Avatar
Cool
Toyota has amended the schedule for all car v6's to the newer schedule of:
90,000 mile belt change & replace the water pump @ 90,000 miles with the timing belt for preventative maint.
This was amended from the previous schedule of:
60,000 miles inspect timing belt, inspect every 15,000 miles indefinately until it needs changing. Change the pump every other timing belt interval.
Because the truck engines are the exact same thing. I suggest that everyone follows the new schedule regardless of the original schedule. This will simplify the timing belt question/answer for all time.
Replace the timing belt & water pump every 90,000 miles.
Old Dec 26, 2005 | 03:16 PM
Ok, not trying to start a fight with anyone on this board... so please don't take offense, these are all opinions and things I have witnessed in this line of work....
the water pump issue seems to be up in the air as to when to change it and what is smart preventative maintence. I have previously stated in this thread about the FIPG issues with the original, factory installed water pumps. The reason for replacement was not normally because the internal operation of the w/pump was faulty, it is 90% due to leaking issues. Once replaced and if replaced correctly there should not be any reason to continue with preventative replacement. I've seen a hand full of 5VZ motors with 200K+ miles who have not replaced their w/pump since the first replacement and have no problems... But I suppose it is personal perogrative on what repairs are done to their veh.
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
