Timing Belt Etc...
Old Aug 23, 2007 | 07:01 PM
toyo4runner's Avatar
Timing Belt Etc...
Hey i was just wondering about 2 years ago my timing belt came off and it happen because one of my tensioners was wobbling, i fix it but just out of blues does it hurt your engine if your timing belt tear off while your driving?
thanks and sorry for the stupid question!
Old Aug 23, 2007 | 07:17 PM
fillsrunner4's Avatar
No i really dont think that belt could harm much in were its at.
Old Aug 23, 2007 | 10:17 PM
pennywize's Avatar
depends on what engine you have...
Old Aug 24, 2007 | 01:59 PM
Adam F's Avatar
He has a 2000 4Runner, that would make it either the 3rzfe or 5vzfe. (he mentioned a belt, that would indicate the 5vzfe) Both are non interference engines. On an interference engine, if you break the timing belt/chain, there is a chance that the valves will "interfere" with the pistons. Basically the valve will smash into the pistons, breaking or bending the valves, and denting/chipping or even shattering the pistons. On non-interference engines there is sufficient clearance between the valves and the pistons so you don't have to worry about contact.
Not a stupid question at all. It's something that EVERYONE needs to know about their vehicles. The 22re is an interference engine, and can/will cause major damage if the chain breaks. 3vze is non-interference. I don't know about the newer generation motors.
Old Aug 26, 2007 | 05:41 AM
Wow i did do this a while back, i was driving and all of a sudden it just stop! The stupid thing is when i opend the hood i didn't check the belt, all i didn't was check battery connection and then i tired to jump start it like 3 times and it didn't start so then i finally saw that my belt was all torned up towed the car to my house and then fixed it, i cost about almost $500.00 for all new toyota parts, belt, water pump (gotta say the water pump bented) 2 tensioner and then it was all set. but after i replaced everything no nocking nothing, gotta say i was lucky to have a non interference engine
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
