Throttle Positioning Sensor
Old Apr 15, 2004 | 08:57 AM
rngrchad's Avatar
I have a 1997 2.7 Tacoma. I believe my TPS is going bad. Here is the symptoms: When driving the truck periodically falls on its face, kinda stalls for just a second and then picks right back up. It does this on cruise control at all different speeds. I notice it most during highway driving and was wanting to re-confirm what I already thought is going on...anybody else believe it's my TPS going bad? What were your symptoms before you realized you needed to replace that throttle positioning sensor?
Old Apr 15, 2004 | 09:33 AM
I had this happen before on a previous Toyota. Exactly the same, some problems with steady driving and less with stop/go. Turned out it was a VERY dirty fuel filter. I imagine that some crud was blocking the flow of fuel. Replaced it and no more problem. Just a thought.
Andrew
Old Apr 15, 2004 | 11:24 AM
Tahoe666's Avatar
Guest
When mine went out it caused a low end stutter. I would step on the gas and it would cough for a second, then go. During this time it was impossible to adjust the timing properly. I replaced it and everything seems to be working properly again. The best deal I could find for a new one was at the stealership, believe it or not. $100.
crammit442
7
Nov 29, 2017 12:30 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
