Throttle body question
Old Sep 16, 2004 | 12:10 PM
03TRDBlack's Avatar
Is the throttle body butterfly (ie. the part that opens up when you push the accelerator to let air in the engine)suppose to open all the way when you have the accelerator floored? I was looking at it the other night and when I put the accelerator to the floor it only opened partially in the throttle body. You can reach inside and open it up all the way, but there is no tension on the cable or anything when you do that. Just curious....
Old Sep 16, 2004 | 12:50 PM
elnip's Avatar
Ideally, when you have the pedal to the floor the butterfly should be all the way open. If not you can adjust the cable or go to the extreme of bending your pedal where it attaches to the cable.
Old Sep 16, 2004 | 11:32 PM
Maddog's Avatar
You dont for some reason have one of those pedal stops coming out of the floor under the accelerator pedal do you ?
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
