Tacoma won't turn over and no power to fuel pump
Old Mar 14, 2015 | 01:12 PM
aunkel2's Avatar
1997 Tacoma I picked up has no power to the fuel pump but the gauge has power. The starter solenoid also is not getting energized. If I jump the starter it will Fire but I don't believe the injectors are firing either. I was wondering if there was a relay or safety kill switch that would kill the power to the fuel pump and starter?
Old Mar 14, 2015 | 02:08 PM
wyoming9's Avatar
Red face
Welcome!!
First the gauge and fuel pump circuits are not connected.
I would check all the circuit protection something might be open.
Poor connections at battery??
You don`t have the air intake system off trying to start it??
There is a starter relay and the circuit opening relay for the fuel pump
As the relay gets information via the ECM
Make sure the battery is charged .
It also does not hurt to clean the ground connections perhaps upgrade .
Old Mar 14, 2015 | 03:24 PM
aunkel2's Avatar
Air intake is all intact the starter relay is clicking and I swapped it with another one didn't change anything. Is there anything between the relay and the solenoid?
puffin04
Jul 10, 2015 09:17 PM
OffroadRalph
Jul 2, 2015 07:28 PM
aciorba23
Jun 29, 2015 04:18 PM
rbravo1
Jun 29, 2015 01:34 PM
Dennis140
Jun 17, 2015 10:37 AM
