Tacoma Lift ??
Old Feb 27, 2005 | 02:21 PM
carose725's Avatar
Question Tacoma Lift ??
Im planning about a 2 1/2'' - 3'' suspension lift on my tacoma and have a question. Should i go with an add a leaf for rear lift of go for shackles. Ive searched the site and see both being used. just wondering which people liked better. im worried add a leaf will make the truck ride much rougher, but i also worry the shackles will ruin my leaf springs. dont know much about either would appreciate some experienced info. thanks.
Old Feb 28, 2005 | 03:01 AM
Tacoma Dude's Avatar
I have an AAL in the back and the ride is rougher back there and the axle wrap is worse than before. I can't comment on the shackles 'cause I've never run them.
For me I have no problems with the AALs so it's all good.
Have you considered just buying a new leaf pack?
Old Feb 28, 2005 | 11:54 AM
carose725's Avatar
i thought about it but i currently dont want to spend over 300 for my lift and all the leaf packs i read about cost quite a bit. i drive this daily and mainly want a more aggressive look with 33'' tires. i only wheel it once every month or two.
Old Feb 28, 2005 | 01:48 PM
futurerunner's Avatar
Have you checked out Revtek?
Old Feb 28, 2005 | 01:57 PM
pinnacle's Avatar
I would look at the deaver aal. It adds 3 leaves your stock pack and gives about 1.5" of lift.
Old Feb 28, 2005 | 04:36 PM
ianshoots's Avatar
How do (longer) shackles damage the leaf pack? Just curious. Shackles and AAL seem to be comparable in price (both about $80 to $100), seems like you might want the shackles if you don't haul much of a load.
Old Mar 1, 2005 | 06:29 AM
carose725's Avatar
ive been checking out this kit it seems like a good price. i emailed another buyer of this kit but havent got a response yet. i think ill order it unless anyone informs me of good reasons not to. http://cgi.ebay.com/ebaymotors/ws/eB...category=33585 . any info will be greatly appreciated. also has anyone installed a similar kit to give me some pointers, i'd like to install it myself to save $$$$.
Old Mar 1, 2005 | 06:46 AM
Jared Ajlouny's Avatar
aal does not contribute to axle wrap, they make the pack stiffer. they do contribute to more wheel bounce beacuse the rear end is so stiff. the reason i got one is because i hate the soft stock ride and i wanted to be able to carry more in the bed.
Old Mar 1, 2005 | 09:01 AM
So you checked out Revtek and....?
Old Mar 1, 2005 | 11:58 AM
carose725's Avatar
the revteck kit was more expensive most places i looked and the daystar kit sounded like a more quality kit. with the bumpstops and extras they include
Old Mar 1, 2005 | 12:05 PM
Originally Posted by Jared Ajlouny
aal does not contribute to axle wrap...
I'm not sure if the AAL contributes to the axle wrap OR if as a result of it the effects are magnified. All I know is that I feel the axle wrap MUCH more than I used to.
Old Mar 1, 2005 | 10:50 PM
KenRiceHilo's Avatar
1. Don't buy the Daystar kit.
2. For a quality spacer kit, look at Cornfed or Toytec. Both make quality products for a really good price but Toytec has much better service.
3. The revtek kit is way over priced.
4. You will need more than 2.5-3 inches of lift to clear 33s.
Old Mar 9, 2005 | 05:46 PM
hallencu's Avatar
If you want 33's I say go with Revtek. It's easy to install and it gives just enough lift to put on some 33's(with the right wheel off-set). It maybe just a little out of your price range but it is alot less expensive than any 4" sus. lift.
Old Mar 18, 2005 | 09:28 PM
ecchamberlin's Avatar
I did the Revtek lift w/ AAL's 2 months ago. The AAL's are great because they make the truck handle a lot better. It is stiffer but not harsh. Watch out for the 33's though. I upgraded to a 16" rim with 4.5" offset and had some rubbing issues. I got the front handled by pounding the pinch weld over and cutting the inner fender liner and fender flares. The back however is a bit tougher. The rear axle is not centered on the wheel well and causes the tires to rub on the back of the wheel well and fender. If you are not willing to do some pounding and cutting you should go with shackles and 32" tires. If you need some specific pic's of the kit installed, let me know. Toytec is priced a bit better than the Revtek and use aluminum spacers instead of cast iron.
Flying91
45
Apr 11, 2024 04:39 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
