T.P. your own Toyota?
Old 03-21-2004, 10:24 AM
WATRD's Avatar
Filtration via a replaceable toilet paper element...
http://www.wefilterit.com/
The concept has been around since at least the 50's, but I hadn't seen it surface for a couple of decades...
Old 03-22-2004, 07:02 AM
Away
Dr. Zhivago's Avatar
I remember this from a long time ago as well. I'd completely forgotten about it. What do you think, Rob? Seem like a valid filter to you? Looks like it's for real to me. Even if it is unconventional...
G
Old 03-22-2004, 08:15 AM
WATRD's Avatar
From the information I can gather, people seem to be very pleased by the system, once they get by the idea of using a roll of T.P. as their oil filter. The concept seems to be sound, with the oil going through multiple layers of medium and I like the fact that the element is cheap and readily available, so you can replace it frequently.
I can't attest to their numbers, I suspect that would vary based upon the quality of the T.P. you buy and I am having a hard time getting around the idea of shoving a roll of Charmin in there and having it protect my engine. But, other than my mental block of thinking of it as T.P., the principle seems sound enough.
Forcing the fluid through the layers of a paper element to clean it is basically all that a standard filter system does, so I can't find fault on that level, but I have a hard time picturing myself grabbing a roll and going out to change my oil.
Old 03-22-2004, 08:33 AM
Guest
4RUNR's Avatar
The real question here is: Charmin or Cottonel?
Old 03-22-2004, 02:02 PM
Tacoma Dude's Avatar
Wouldn't the softer rolls be worse?
Seems to me that the extra "cushy" linty part would be carried away by the oil.
Old 03-22-2004, 02:25 PM
Never mind
Originally Posted by Frantz website
Can't I still use any brand or type of TP for my Frantz Oil Cleaner/Filter?
When the Frantz Oil Cleaner/Filter was first invented, the variety of Toilet Paper choices was slim! It is true, that you used to be able to go into any grocery store and buy the brand on the shelf. Unfortunately, this has changed in the last 20 years. The choices of Toilet Paper available today can confuse the average person! For optimal performance of the Frantz Oil Cleaner/Filter, it has always been recomended to use a 2 ply 500 sheet per roll, facial quality Toilet Paper. The purpose for these specifications is so that you will obtain the most densely packed roll of TP available. If you cannot find a 2 ply 500 sheets per roll in your favorite grocery store, we suggest that you try the comercial or janitorial supply companies to find some. If you still cannot find or buy any, we do have it for sale either in four packs or by the case!
We have also heard that a 1 ply 1000 sheet TP has also worked(Scott 1000).
Old 03-22-2004, 02:43 PM
midiwall's Avatar
My guess is that using scented would be a bad thing... Adding the chemicals to your crankcase would be .. ummm... "schweet".
Old 03-22-2004, 05:59 PM
jharris2's Avatar
May not be the same brand, but we used a TP oil filter on the family 1962 Ford Fairlane 500...the 260 V8 ran great until it had about 160K miles on it.
Old 03-22-2004, 06:05 PM
gwhayduke's Avatar
Ran the crap out of it?
Old 03-22-2004, 06:17 PM
jharris2's Avatar
I guess that's one way to look at it!!
Old 03-23-2004, 01:52 PM
SLC Punk's Avatar
First time I have heard of this.. I am a little hesistant on doing that to my engines..
Old 05-21-2004, 07:42 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Now I know what to do with those 2,000 rolls of Osama TP rolls I bought off the Internet...
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
crashburnoveride
08-28-2015 09:20 PM
nick b
07-11-2015 04:38 AM
Quick Reply: T.P. your own Toyota?
